Suspension Coils goong on soon!
Old Oct 4, 2012 | 10:00 AM
GOC4RT's Avatar
GOC4RT
In final, I am getting H&R coils. They don't come with top hats and I will be replacing them with tops from a JCW sport suspension.
There is a tool BMW # 31 2 210 (Hazet) that I apparently need to do this. Is there any other substitute for this? Do I buy it from a BMW dealer?
Old Oct 4, 2012 | 10:31 AM
slinger688's Avatar
slinger688
You would need a spring compression tool. This will help you remove the springs that is under compression. I got mine at harbor freight not sure if that is the tool you have listed.
Old Oct 4, 2012 | 04:46 PM
mbwicz's Avatar
mbwicz
By top hats do you mean the upper shock mounts for the front, AKA camber plates? To get those off, you just need a spring compressor (I borrowed one from Autozone), metric allen wrench, and metric combination wrench. Removal was not bad at all. Some guys will say that you won't need a compressor, but that is your choice.
Mike
Old Oct 5, 2012 | 09:31 AM
Creeve's Avatar
Creeve
Mike
+1 on Autozone rental
Upper suspension mount or top hat are synonymous terms. They are only referred to as camber plates when they are adjustable. The OP's JCW top hats are not adjustable. Just so everything is clear.
Old Oct 5, 2012 | 03:48 PM
GOC4RT's Avatar
GOC4RT
Yeah thanks guys!
I found out how to undo the front struts.
13/16th spark plug socket and an Allen key through the top. That's at least what I got out of it all.
Here's a pic.
Old Oct 5, 2012 | 05:20 PM
slinger688's Avatar
slinger688
Good idea. Now comes the fun part, releasing the tension in the spring and putting it back. Please be real careful releasing spring tension.
Old Oct 5, 2012 | 05:38 PM
mastermason11's Avatar
mastermason11
Make sure you check the clearance of the AC line and your axle to make sure they do not rub. Otherwise, overtime, it will leak freon and you lose AC.
Sent from my iPad using NAMotoring
Old Oct 5, 2012 | 05:40 PM
GOC4RT's Avatar
GOC4RT
True, Where is that all located so that I can keep an eye on that. I am not slamming the car either. I am done with dumped cars.
BTW Monday the set-up is going on. Pics are coming!
Old Oct 5, 2012 | 05:41 PM
mastermason11
It will be the aluminum hose that is very close to the axle on the front right wheel well.
Old Oct 5, 2012 | 05:45 PM
GOC4RT's Avatar
GOC4RT
Okay! Thanks for the heads up!
Old Oct 8, 2012 | 06:45 PM
GOC4RT's Avatar
GOC4RT
Hey guys,
So I lowered the Mini today. I am 1 finger away from the AC line... Is that safe?
Sorry for the crappy pic I don't feel like going back to the garage.
Old Oct 10, 2012 | 09:59 AM
GOC4RT's Avatar
GOC4RT
Here are some pics! I might be putting it back to stock. I am really pissed at the vibrations in the driveshaft.
Attached Thumbnails Coils goong on soon!-image-762345008.jpg   Coils goong on soon!-image-1048298519.jpg   Coils goong on soon!-image-1647161193.jpg
Old Oct 10, 2012 | 02:24 PM
NewCooperFanatic's Avatar
NewCooperFanatic
Damn that sucks, sounds like you went too low.
Old Oct 10, 2012 | 03:04 PM
slinger688's Avatar
slinger688
How much was your drop after lowering? About 1 1/2"?
Old Oct 10, 2012 | 04:13 PM
Eddie07S's Avatar
Eddie07S
Car looks really nice...Sorry to hear about the vibration.
There is a thread that I was following about a year ago that discusses this problem in detail. While the gist of it is that it has to do with the drive shafts being too straight, it is also somewhat random. Is there room in the springs to raise the front to see if it goes away? You can also put spacers between the camber plates and the strut tower to raise the front. If that works, the back will need to be done too.
vulkandino
Oct 31, 2015 08:29 PM
crashd22098
Oct 9, 2015 07:30 PM
randeez
Oct 5, 2015 09:23 AM
muddflapp
Sep 20, 2015 03:55 PM
cguzz
Sep 20, 2015 03:42 PM
