power steering motor over heating.
Old Oct 3, 2012 | 04:26 PM
Yyrd's Avatar
Yyrd
Other day i had a flat tire. I puled off the road and my power steering fan sucked in some dead grass. The day that i replaced the flat tire my power steering motor died. After the car sitting it turned on again. This is telling me that it is not dead but overheating.
I drove the car home and got underneath it and found the fan clogged with grass and not spinning. I pulled the grass out and the fan works again. yay problem fixed!. Well so i thought.
I got in car, power worked fine for 3 minutes and poof no power again. Still overheating! Checked fan and its working fine.
help? please!
on a side note i just put the car together a week before due to a new clutch. but worked fine till the flat tire bit.
Old Oct 9, 2012 | 03:20 PM
TheMINIwhisperer's Avatar
TheMINIwhisperer
Check your power steering fluid (in the black cannister next to youre coolant resevoir)...make sure you have fluid. if fluid level is ok, but its still acting up, your pump is probably shot. you can take it to the dealer and have them read fault codes, most likely youll have a fault for power steering pump if it is faulty. its a little pricey too. : / good luck man
Old Oct 11, 2012 | 01:11 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Have you checked the fan's functioning? You can read more on it here: http://www.pelicanparts.com/techarti...eplacement.htm
888.280.7799 | 6am - 5pm PST
Old Oct 11, 2012 | 01:15 PM
Yyrd's Avatar
Yyrd
fan seems to blow fine. i get about ten minutes drive time before it overheats.
Old Oct 11, 2012 | 01:33 PM
r34king's Avatar
r34king
The fan doesn't really do what they say it does. I took my fan off about 4 months ago to do my oil pan gasket and didn't put it back on. Power steering still works fine. I'm betting the pump is just dying
Old Oct 11, 2012 | 01:40 PM
Yyrd's Avatar
Yyrd
pump needs cooling fins, like on well pumps. hmmm maybe an aftermarket upgrade somebody should make
Manny_cooper
Sep 10, 2015 11:09 AM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
