Car Stalls...
Old Oct 12, 2012 | 05:35 PM
abdielhiram's Avatar
abdielhiram
Car Stalls...
Hi All
Hoping to get some advice here.
Suddenly today, after I drove the car, I filled up the tank with gas, then noticed, the car stalls from 3,000 - 4,000.
Mine is a Cooper, Non S, year 2003, and AT. I was using the Tip-Tronic.
Not sure what could cause this, I checked the Air Filter and all Air hoses, in case of an Air leak, but that does not seems to be the problem..
Any Ideas o advice will be appreciated.
Abdiel
Old Oct 12, 2012 | 07:42 PM
abdielhiram
I have read this
https://www.northamericanmotoring.co...0-bad-gas.html
Same symptoms, I had reset the ECU Manually, the car still stalls..
Should I just empty my Tank and refill it from another station?
Please Help :(
Old Oct 12, 2012 | 10:50 PM
abdielhiram
For the records....
I you are using a K&N Filter on an R50 (Not sure if its applicable to other models) there is a "gasket" that should be installed with the filter.
I have checked that gasket to mke sure it was properly installed, and also tight the 2 bolts for the Airbox as well..
That seems to do the trick...
Thanks Everyone and hope this helps anyone in the future...
elightbo
Aug 17, 2015 01:50 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Dashdog
Aug 10, 2015 06:17 AM
PatrikKN
Aug 5, 2015 09:10 PM
