Suspension Help: Coilover problem
Old Oct 1, 2012 | 02:30 AM
DjR53's Avatar
DjR53
ive been doing a reinstall of vmaxx coilovers on the rear because the top part cracked, but ive seem to hit a problem i cant reinstall the 22mm bolt on the bottom, it just never seems to align right with the trailing arm ill ge it 3/4 of the way in, and then tightening becomes impossible, any ideas? Note i have rear control arms with some negative camber..any help would be appreciated
Josh
Old Oct 1, 2012 | 12:45 PM
blue2turbo's Avatar
blue2turbo
Have you checked the bolt and the threads to make sure you didn't cross thread it by accident?
Old Oct 4, 2012 | 10:04 PM
Mini7's Avatar
Mini7
Use a jack to lift the trailing arm or to compress the shock so that the bolt holes line up. I seem to run into this on the LHS rear shock. The trailing arms is about 1/2" lower all the time.
Old Oct 4, 2012 | 10:13 PM
COR BLMY's Avatar
COR BLMY
yes first check the bolt and threads . does it go in without the CO in place ?
may also try installing the bottom bolt first or with the top ones just started
Old Oct 31, 2012 | 05:18 AM
SneedSpeed's Avatar
SneedSpeed
Sounds like the bolt and or nut is cross threaded. Once you fix that, Use a jack to move the trailing arm up to meet the shock. When the bolt will slide though easily then tighten by hand. Dont use an impact wrench to start the bolts.
Old Nov 1, 2012 | 12:14 PM
LLZuB's Avatar
LLZuB
put the bolt in from the front and see if it threads through all the way and clean up the threads a bit. This will tell you if it's cross threaded or if you're not lined up right. Clean off the threads inside the trailing arms with some PB blaster and also the bolt and try re-installing the right way.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Hippiehobbit267
Dec 3, 2019 04:22 PM
Bea5tMa5ter
Aug 27, 2015 01:42 PM
luisfv56
Aug 22, 2015 12:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
