R50/53 Need Some Bolt Torque specs (03 Mini)
Old Sep 28, 2012 | 10:54 PM
Tinythumb's Avatar
Tinythumb
I am trying to find out the CVT transmission pan bolt torque in inches or foot pounds. Is there a website that has some general torque lbs for a 2003 Mini cooper?
Thank you!
Old Sep 29, 2012 | 04:48 AM
Capt_bj's Avatar
Capt_bj
nothing in the Haynes - only covers manual trannys
Old Sep 29, 2012 | 08:34 AM
bmwr606's Avatar
bmwr606
Thank you!
called my buddy that owners a tranny repair/overhaul shop and he could not find a torque for the pan bolts
however, his documentation did stress a specific criss-cross pattern for both removal and reinstall
he said the torque would depend on the type of gasket, if it has metal "rings" at the bolt holes, use the standard torque for the bolt size, if no metal then less, but again it depends on the type of gasket material
also, his documentation does not say anything about any sealant
sorry i could not be more help
scott
Old Sep 29, 2012 | 08:35 AM
cristo's Avatar
cristo
Alliance Member
BMW TIS says 9 Nm, which is 80 in-lbs or 6.6 ft-lbs.
Old Sep 29, 2012 | 11:29 AM
Tinythumb's Avatar
Tinythumb
Thanks for the information you all have provided. It is a normal pan with a gasket no washers or spacers. when i checked mine it was at 30in-lbs so 2.5lbs. cristo had 6.6ft-lbs but i will stick with what i have for now.
yukinoinu
14
Jul 2, 2016 07:27 AM
Mini'mon
Aug 16, 2015 04:15 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
minipopkart
Aug 9, 2015 12:13 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
