Engine Turns off while coasting
Old Sep 27, 2012 | 08:52 AM
protodon's Avatar
protodon
I have a 2007 Mini Cooper Base model and I've been having an issue in the past few months where the engine will turn off while I am coasting with clutch pressed all the way in. Only the engine shuts off, all other lights and operations are still running.
If I am coasting around 60 mph and in 6th gear and I see the rpms go to 0, sometimes I can press the gas pedal all the way in and after a few seconds the engine will come back to life, of course revving very high for all the gas I just gave it. But if the rpm's go to 0 and my speed gets too low, giving gas won't restart it and I will have to restart manually with the push button.It does start up right away every time though.
I feel like this happens more frequently when my gas tank is full but it has also happened when I am around a 1/4 tank or so, less frequently though.
The check engine light comes on and off intermittently, I had a mechanic check it and it said 'Misfire in Cylinder 4' I'm not sure if this is directly related because I've had issues where I needed to change sparkplugs and the symptoms were totally different when that was happening. I would lose power while driving, no engine turn off like this case. Would replacing the coil or sparkplug in that cylinder make sense as a fix for this?
Any other recommendations to fix this. I've had the car without issues since 2007 and this just started around March. it's not the worst problem to have but it can be very annoying and I don't want it to get worse, obviously.
Old Sep 27, 2012 | 09:08 AM
wandrur's Avatar
wandrur
Moderator
A single cylinder misfire shouldn't shut down your engine. I would be suspecting a fuel pump issue or an ECU issue with these symptoms.
Old Sep 27, 2012 | 04:10 PM
33EJB's Avatar
33EJB
If I am coasting around 60 mph and in 6th gear and I see the rpms go to 0, ...
So... why are you coasting (especially at around 60 mph) with the clutch pushed all the way in?
Or did I misunderstand ???
Old Sep 27, 2012 | 05:48 PM
bmwr606's Avatar
bmwr606
Originally Posted by 33ejb
so... Why are you coasting (especially at around 60 mph) with the clutch pushed all the way in?
Or did i misunderstand ???
+1,000,000
Old Sep 27, 2012 | 06:55 PM
schatzy62's Avatar
schatzy62
I am confused by part of what you are saying.
As i understand it you are moving at 60 miles an hour and push the clutch in and hold it in. The engine stops and while still holding the clutch in you press the gas pedal and the engine will start back up without anything like a starter motor or cluch engagement to cause the engine to turn over and start.
If that is truely the case then i dont see how that can happen.
It sounds to me as if maybe you have an electrical malfunction in the tach.
But of course if you are engaging the clutch when the engine is off and the car is doing 60 miles an hour yes the engine should start back up.
Old Sep 28, 2012 | 06:15 AM
ZippyNH's Avatar
ZippyNH
Step 1, learn how to drive a stick....coasting out of gear is a no-no.
step 2, sounds like a shop with a data logger odb2 port plug in would be useful....plug it in, then drive, duplicate....then look at the data.....
Any chance the car has auto start enabled? Some mini's can be programmed to SHUT OFF at traffic lights, out of gear.....automaticly, then restart.....
Old Oct 1, 2012 | 02:17 PM
protodon's Avatar
protodon
I coast as much as I possibly can while driving this car. I get a solid 43 mpg doing this. Yes I know it's supposedly bad but I have been driving my car this way since i drove off it off the lot in 2007. It now has 133,000 miles on it and so far, this engine issue has been my biggest problem with it. So I am going to stick to my driving style. Now keeping in mind that I have been driving this way for five years, it doesn't have auto start and it's not caused by coasting with the clutch pressed in because it only started to happened recently, anyone have any other ideas?
I mentioned in my original post that I did have a mechanic read the code and it came as cylinder 4 misfire, months later I went to an auto zone, actually this was just two weeks ago and they gave me a code of 1632, thermostat heater control circuit open. Would this make sense to anyone? I'm not very inclined to trust it because they were using the VW setting to read my codes since I guess mini wasn't in their OBD.
Ultimately I guess I am going to have to take it to the dealer, I was just wondering if anyone experienced something similar. It seems like the answer is no.
Old Oct 1, 2012 | 05:47 PM
33EJB's Avatar
33EJB
I coast as much as I possibly can while driving this car. Yes I know it's supposedly bad but I have been driving my car this way since i drove off it off the lot in 2007.
I've been driving manual trans cars for 40+ years (yes I'm old - - what's it to ya?) and I can't remember ever coasting like that on purpose. There's really no need for it in any circumstance that I can think of. I can think of lots of reasons NOT to, but...
Whatever floats your boat.
Most people probably haven't experienced anything similar, because I suspect you have a unique driving style/problem there.
Let us know what you find out from the dealer.
__________________________________________________ __
Old Oct 1, 2012 | 05:50 PM
miniblucabrio's Avatar
miniblucabrio
I had a similar problem in a different car. When I would push the clutch in to change gears the car would stall. When I let the clutch out it would start back up. Turns out this was caused by a loose ground connection for the battery. Try checking all the ground points.
Old Oct 8, 2012 | 09:02 AM
33EJB's Avatar
33EJB
Believe it or not, I actually tried this (coasting @ 60+ mph) yesterday on my way home. Very little/no traffic on the highway, I thought - - what the heck, let's just see what happens... pushed in the clutch & held it in for a while, even tried shifting to neutral while coasting.
So what happened? Short answer - nothing. Engine settled into a normal idle while I rocketed (almost) silently down the highway. I let it coast a while until speed dropped quite a lot, then I put it back into 6th gear, revved the engine a bit to match revs to speed, and motored on normally. No drama.
Would I do it again? No. It was just an experiment to see if I could reproduce the problem that the OP reported. My engine responded just as I expected - no stalling, nothing, just a smooth idle.
For what it's worth.
Old Oct 11, 2012 | 10:16 AM
Denzien's Avatar
Denzien
I don't suppose this happens at stop lights too, eh?
Old Oct 16, 2012 | 06:16 PM
schatzy62's Avatar
schatzy62
I would be willing to bet that the engine never really stops turning over as there is "absolutely" no way for it to start up again just by pressing the gas pedal.
I would also be willing to bet if the engine rpms were checked by an external source that the engine is still running during the coasting.
I would also be willing to bet that it is an electrical malfunction with the tach.
Old Oct 16, 2012 | 06:53 PM
gregsmini's Avatar
gregsmini
Sounds like you're a betting man!!
Old Oct 16, 2012 | 07:41 PM
bmwr606's Avatar
bmwr606
page 101-102 of my cms all4 owners manual:
Never drive with the clutch held down,
with the transmission in neutral or with
the engine switched off
; otherwise, engine braking
action will not be present or there will be no
power assistance to the brakes or steering.
page 108
Coasting
When approaching a red traffic light, take your
foot off the accelerator and let the car roll to a
stop in the highest gear possible.
On a downhill gradient, take your foot off the
accelerator and let the vehicle coast in a suitable gear.
Fuel supply is shut off automatically when the
vehicle is coasting.
scott
Old Oct 17, 2012 | 08:15 AM
Tio Barry's Avatar
Tio Barry
Well, I grew up driving freewheeling SAABs. First one was a brand new 1969 model 96. A freewheeling transmission disengages the drivetrain when you lift off the accelerator. Safety? I'm still here to talk about it!
Old Oct 17, 2012 | 10:27 AM
bmwr606's Avatar
bmwr606
as i recall it was a very troublesome system, the sprague clutch was a weak link, expensive to replace and labor intensive to install
i helped a friend replace sprague clutches in his saab sonnet and sedan several times
it was a mechanical attempt at dealing with lift throttle oversteer
Old Oct 18, 2012 | 10:58 AM
NewCooperFanatic's Avatar
NewCooperFanatic
Jeez folks, who gives a crap how he drives HIS car.
If he likes to drive like that then let him. He was asking for help on a particular issue he is having. He never asked opinions about his driving style.
Old Oct 18, 2012 | 01:37 PM
Tio Barry's Avatar
Tio Barry
My '10 Cooper Auto will occassionally stall out while coasting in neutral. Have had it to the dealer a couple of times.
BTW the SAAB freewheel originated in the two stroke oil in the gas mixer engines to prevent loss of lubrication while engine is decelerating.
Old Sep 3, 2015 | 11:43 AM
mimaal's Avatar
mimaal
Did you ever find a fix for this? I just experienced this today for the first time, both when I was waiting at a couple stop lights and when I was coasting at 30mph before a turn. There's no shuddering, or noise, all of the lights/radio/AC stays on and pushing the button turns the engine back on however, unless I'm actually pushing the gas pedal the car wants to shut off.
Old Sep 6, 2015 | 12:55 AM
Systemlord's Avatar
Systemlord
@OP
Perhaps your engine wouldn't stall if it had sufficient RPM's do to a misfire, many of us get misfires and our engines continue to run. The OP might not be saving on gas but even if he was it's offset hugely when you reduce your braking power assist potentially risk causing a major accident to someone other than the OP when you loose your braking power assist, put undo stress on your throw-out bearing. This makes absolutely no sense for the sake of MPG.
Perhaps he is no longer with us, or perhaps his Mini lost braking power assist and the unthinkable happened. He was rolling the dice for himself and other's in front of him for a few MPG.
Old May 25, 2018 | 12:36 PM
Carlton's Avatar
Carlton
Engine loses power shifting from 3rd to 2nd turning corner
while down shifting to turn corner my mini will appear to be functioning but no acceleration so I look at RPM’s and it is at 0. Everything appears to function as normal but obviously you cannot accelerate and if your heater/fan blower is being used the blower is the only thing that stops. This is an intermittent problem that happens more frequently during cold weather & lesser in damp weather. Always when down shifting from 3rd to 2nd more frequently when turning corners and occasionally when slowing to stop at intersections. No warning indicator lights appear, and no codes either. A push of the ignition button and the cars resumes where it left off. It never does this with my fiancé but I have had passengers witness it. Since I have become accustomed to this issue and navigate it well. Last winter it became more predictable when turning the corners so I learned to watch the RPM’s, during process of down shifting & acceleration the RPM’s drop to just above “0” and catch & jump back up. When the car fails the RPM’s drop all the way to “0”. I press the ignition button and continue on my way. When I first experienced this I spoke to my trusted personal mechanic back in my hometown, someone I knew had vast knowledge & I could trust. I explained everything I had learned & the consistent details I had observed. My mechanic told me to remove where the air intake connects to the manifold, to access the throttle plate bores. He stated the bores had too much carbon build up and the plate was sticking causing the intermittent power loss. He instructed me to spray carb cleaner on a rag and wipe the bores the best I could and that this problem would continue to occur more during the colder winter temperatures. And it did. I couldn’t get my fiancé to agree or even try to disprove my mechanic by doing what he instructed to see if it stopped. My thoughts were if you don’t agree they best way to prove or disprove someone is by doing exactly what they say, if it doesn’t work they were wrong & you were right. My fiancé didn’t fall for that. So the car still has this issue. I’ve taken it a reputable shop. They can’t duplicate it and there are no codes or faults. I can’t make it happen while driving so I can’t show the shop mechanic. So I’m either going to have to get greasy myself (no problem there) or take it to my old mechanic 2-1/2 hours away. This previous post is the first I have read where someone has experienced something close to my issue. And I have been googling the **** out of it! If any of you knowledgeable individuals have any input please reply! Thank you!
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
patrioticmini
Aug 20, 2015 10:54 AM
tylewis
Aug 18, 2015 06:53 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
