R58 Coolant Temp Sensor service bulletin
Old Sep 21, 2012 | 01:10 PM
randers51's Avatar
randers51
I just had my Coupe in for the coolant temp sensor recall issue. I got a good detailed description of the reason for the recall and what the fix was. The original T-stat in the Coupe and other MINIs had the coolant temp sensor integrated with it. This sensor was giving some false signals to the computer causing numerous different errors along with possibly causing the fan to run for an extended time after the engine was shut off. The fix was to install a new coolant hose with a fitting that has a new separate coolant sensor. Then a new wiring connector was included that had the two wires for the T-Stat separate from the two wires for the coolant sensor which then went to the new sensor. Hope that helps everyone understand the issue.
Old Sep 21, 2012 | 01:22 PM
CHKMINI's Avatar
CHKMINI
Mine gets replaced on Monday. My Scangauge has been throwing temps all over the place from the normal 227 degrees to 238 and down to 218 degrees. I knew something was malfunctioning and now I have the answer. thanks
Old Sep 21, 2012 | 02:25 PM
bmwr606's Avatar
bmwr606
had mine done a couple weeks ago, took 45 minutes including a free car wash
i was having no problems and have noticed no difference in the behavior of my cms all4
scott
Old Sep 22, 2012 | 12:06 AM
Rejeme's Avatar
Rejeme
Randers, do you think you could post a pic of the part they added?
Old Sep 22, 2012 | 01:19 AM
bmwr606's Avatar
bmwr606
here is a link to photos of the coolant temp sensor sb on my cms all4
https://picasaweb.google.com/1043068...eat=directlink
scott
Old Sep 22, 2012 | 10:30 AM
reducati's Avatar
reducati
what model dates for the coupe is affected? i havent recd any notice.
Old Sep 22, 2012 | 09:10 PM
TerminalVelocity's Avatar
TerminalVelocity
Ya no notice for me as of yet either. I left a message with one of my friends who works at MINI to check into it for me. Thanks for the details on what's occurring! Really appreciate it.
On second thought maybe I'll just sell my Coupe and go by a FIAT due to that awesome ad for the FIAT 500 on our forum page. I mean seriously?
Old Sep 22, 2012 | 09:26 PM
JoanieB's Avatar
JoanieB
Think about it this way... FIAT is giving this forum money to run that ad. Every time one of us clicks on it, this forum gets a bit more $$. Sooooo FIAT's money is supporting a MINI enthusiast group. Gotta love capitalism!
Old Sep 25, 2012 | 10:33 PM
adcam's Avatar
adcam
Same here, no letter yet. Had my car since Jan.
Old Sep 26, 2012 | 09:06 AM
glennaa11's Avatar
glennaa11
I didn't get anything either. Does this only apply to JCW's or something? Mine's Justa.
Old Sep 26, 2012 | 09:34 AM
JoanieB's Avatar
JoanieB
I emailed my SA with my car's VIN and she is included in the recall... 2011 MCa. So yes, it applies to Justas too. Looks like it applies to ALL models within the time frame, but I don't know for sure what the time frame is. Best thing to do is to have your VIN ready and call or email your local SA. The letters probably are in the process right now, this is very recent and the dealerships needed to have some replacements on hand before the tsunami of MINIs came rolling in.
I'm going in next Tuesday.
Old Oct 8, 2012 | 05:16 PM
Cruzer214's Avatar
Cruzer214
Just brought my coupe in for service today and they said my car is part of the recall. I believe my justa was built in feb
Old Oct 8, 2012 | 07:05 PM
socouper's Avatar
socouper
My Justa was 4/12 build, I just had mine at the dealer and they said mine wasn't included.
Old Oct 9, 2012 | 09:35 AM
byron h's Avatar
byron h
When I took my MINI in for routine service, I mentioned that my ScanGauge was showing temperatures approximately 20F lower than when the car was new. My dealer replaced the coolant sensor. I mentioned that I had not received notice of any recalls. The dealer said they are just starting to send them out. After this change, my coolant temperature is running around 220F max. like when new.
2011 MC PW/B Built 10/10
Old Oct 9, 2012 | 09:51 AM
CHKMINI's Avatar
CHKMINI
It's not a recall therefore you won't get a notice. It's merely an upgrade that they will perform if/when you have your car in for service or another issue. I suggest that you call your SA, provide your VIN and see if you are eligible for the upgrade.
Old Oct 9, 2012 | 01:12 PM
MarinePMI's Avatar
MarinePMI
Had my SA run my VIN, and Betty is not included. (3/12 build date; Coupe S)
Old Oct 9, 2012 | 01:30 PM
bmwr606's Avatar
bmwr606
looks like 03/2012 may be the cutoff date for this
my dad's 09/2011 build 2012 cms all4 auto was included,
my 03/2012 build 2012 cms all4 manual was included
another poster said his 04/2012 build was not included
scott
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
