R50/53 flat tire!!!
Old Mar 25, 2004 | 03:57 PM
yudman's Avatar
yudman
i was driving and my flat tire monitor went on(i have run flats). I immediately started clokcing the miles and onyl have 15 or so, should i bring it to goodyear or MINI, will mini charge for anything?
Old Mar 25, 2004 | 04:11 PM
jsun's Avatar
jsun
Wow, the wonder of the online world is that someone would ask the Internet what to do about a flat tire instead of just calling a mechanic...
Whether you get it repaired by Goodyear (or any tire shop) or the dealer, either way it's at your expense. Your warranty doesn't cover flat tires any more than it covers running out of gas. But assuming the puncture is on the flat of the tread, it should be repairable. And while you can go many more than 15 miles on the "flat" runflat, you should still get the repair done a.s.a.p.
Good luck! :smile:
Old Mar 25, 2004 | 04:14 PM
minimotorin's Avatar
minimotorin
reset the monitor and drive a little more and see if it comes on again. Sometimes a wheel will spin on something (water, sand, etc.) and will trigger the sensor.
Old Mar 25, 2004 | 04:17 PM
Devlen's Avatar
Devlen
If you should need to replace I have a pair of 16'' runflats with 75miles on them for sale.
Old Mar 25, 2004 | 04:19 PM
Me.Mini's Avatar
Me.Mini
I've had my light come on for reasons other than a flat before. check your pressure the old fashioned way first
Old Mar 25, 2004 | 05:40 PM
boilermini's Avatar
boilermini
My sensor goes off at least once a month. I've never had a flat yet. When I check the tire pressures , sometimes the difference is only 3-5 psi lower than the other tires! It usually happens with a extreme weather change (crazy Indiana weather).
So. my advice, check your pressures, reset the monitor and keep driving.
Old Mar 25, 2004 | 05:50 PM
MINIMINA's Avatar
MINIMINA
runflats are awesome
Old Mar 25, 2004 | 08:13 PM
H&J's Avatar
H&J
I know this is a bogus post from me, but I'm far from Indiana these days, in California via Boulder, Colorado. You were a Boilermaker! Me too. Just had to say hi... B.A. journalism 1985, M.A. 1993... is your Mini gold and black??? Mine WILL be IB/W MCS.
Old Mar 25, 2004 | 08:18 PM
lotsie's Avatar
lotsie
>> drive on snow and ice never had wheel spin trip anything
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
