STX (Street Touring X) 15" Azeni Pressure ???
Old Mar 25, 2004 | 01:26 PM
FWD-MX5's Avatar
FWD-MX5
I am going to drive an event in STS (I have a regular MINI) w/the H stocker and would like to know the pressures the fast guys in STX are using for 15" Azeni. I searched and found Randy Webb runs 35f/37r any other suggestions? I have 15x7 Volks, Koni SAs SS+ springs and rear bar and like just a little oversteer. Thanks for the help.
Chris
Old Mar 25, 2004 | 02:18 PM
BGarfield's Avatar
BGarfield
Chris, between 30 and 40 psi, the tires won't roll over. It just depends on how fast you want them to heat up. If it's cold, run in the low 30's, if it's hot, run in the high 30's/low 40's. Believe it or not, shown with a pyrometer, it doesn't make a difference.
This is all assuming you have negative camber (2.0 or better up front). If you don't you'll probably want to run the high 30's for front and the rear just depends on the rotation you want.
Brian
Old Mar 25, 2004 | 02:29 PM
FWD-MX5's Avatar
FWD-MX5
Brian I have -.5 camber up front. The car is H Stock legal, but a practice event is coming up and with no points on the line I want to try Azeni. The weather here has been chilly, we barely reached 70 yesterday. California dreamin'....
Chris
Old Mar 25, 2004 | 03:21 PM
BGarfield's Avatar
BGarfield
I'd start around 33psi. If they roll add 2psi at a time. They'll stick like glue with minimal pressure. You're right on the border for temperature, so be careful they don't get too warm.
Brian
bahman
Feb 14, 2016 10:29 AM
Oct 1, 2015 12:13 PM
eliseo1981
Sep 30, 2015 07:57 PM
Emnotek
Sep 29, 2015 07:37 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
