R50/53 can someone explain wheel weights to me?
Old Aug 30, 2012 | 01:42 PM
micromini234's Avatar
micromini234
I just got new tires of warranty and well it seems like they took of the wheel weights and left one on, is this a mistake or should they be doing htis?
Old Aug 30, 2012 | 01:55 PM
Mical's Avatar
Mical
They should've rebalanced your tires and you'ld have weights in different spots than where they were on previous set.
Old Aug 30, 2012 | 01:57 PM
micromini234
thanks for the quick reply, even if some of them dont have any? and would that throw of an alignment?
Old Aug 30, 2012 | 02:15 PM
MINIdave's Avatar
MINIdave
Tire weights have no effect on your alignment, they're two separate things.
Mical is right, new tires will require weights of differening amounts and positions from those on the old tires. If your tires are running smoothly now you have no issue. If your car is pulling, you may have an issue with your alignment, but it has nothing to do with having your tires balanced unless the shop somehow damaged your car by hitting a curb on a test drive or something, which is highly unlikely.
If your tires are shaking when you drive between 45 and 65 mph, you may have to have them rebalance them
Old Aug 30, 2012 | 02:22 PM
Jim Michaels's Avatar
Jim Michaels
It usually takes some weights to properly balance a wheel/tire combination, but not always. Balancing doesn't affect alignment, but an out-of-balance wheel/tire can produce a vibration at speed, especially if it's on the front. If you don't feel any vibration, they're probably okay. Even if properly balanced initially, a tire that wears unevenly can become unbalanced and produce a vibration.
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
eatsleepautox
Oct 30, 2015 06:46 AM
theblackfalcon
Oct 11, 2015 09:49 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
Chippawaguy
Aug 18, 2015 11:17 AM
