wastegate vacuum issues
Old Aug 21, 2012 | 02:59 AM
crane's Avatar
crane
I have a mini clubman diesel, for the last few weeks the turbo has been intermittent.
The fault lies I believe with the vacuum side....the wastegate cutting in and out randomly.
I have a small amount of vacuum left in the vacuum tank after the engine is turned off so that seems to rule out a leak.
I am left with 2 possibles , the pressure converter or map/pressure sensor.
Does anyone know where these are located and if either is a common fault?
The fault can also be cured by turning the ignition on and off?????
any help appreciated
thankyou
Old Aug 21, 2012 | 03:27 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Wow a Clubbie Diesel ! How cool is that !
Wish I had a clue for ya.
Only diesel I have ever had was non-Turbo VW.
GL !
silence2-38554
98
Sep 21, 2016 02:52 PM
hooverr77
Sep 11, 2015 10:51 AM
tag1260
Aug 24, 2015 05:52 PM
patrioticmini
Aug 20, 2015 10:54 AM
WestfaliaR
Aug 19, 2015 08:01 AM
