R50/53 Problems after new front strut install install
Old Aug 14, 2012 | 03:59 AM
STF_U's Avatar
STF_U
Hi everyone, I have a question for you all. My wife has a 2003 Just-a-Cooper, and I recently installed new front struts on it because they were blown when we bought it. Well, after the install the car tends to pull to the right (more than a slight pull I would say). Not only that, but the steering wheel also seeming turns itself in that direction (if that helps).
I have my own alignment tool and do my own alignments and everything checks out just fine.
Now, the weird thing is, if you are driving down the road and make a few turns the car will start to pull slightly to the left. Keep driving, make a few more turns, and it will start to pull to the right again.
Any thoughts on what is causing this???
Thank you any advance for any help you can offer
Old Aug 14, 2012 | 04:45 AM
ZippyNH's Avatar
ZippyNH
If you are sure the alighnment is fine, it sounds like bushings...but when they are worn, a car is often unalighinable....just cause of the results you see driving...interesting though it started AFTER a suspension change....
strut towers were ok...no mushrooming? Common issue on gen1 cars, can cause issues too!!
Old Aug 14, 2012 | 06:42 AM
bmwr606's Avatar
bmwr606
look at the rear suspension
Old Aug 14, 2012 | 10:20 AM
IQRaceworks's Avatar
IQRaceworks
What kind of "alignment tools" are you using to align your front end?
Old Aug 14, 2012 | 01:19 PM
STF_U's Avatar
STF_U
ZippNH - On your last comment there, I looked over the car's front end last night and notice that both strut mounts are in fact cracked 9the passenger side is much worse than the driver side). I am guessing this is the cause of my problem and have already ordered new mounts.
IQraceworks - I use the FASTTRAX wheel alignment tool, it measures camber, caster and tool. cost me almost $200 but well worth it. Since I regularly autox my car and both my wife and myself enjoy modifying our cars I bet I has used that thing at least 20 times since I bought it.
Old Aug 16, 2012 | 04:21 AM
STF_U's Avatar
STF_U
No other thoughts? Any confirmation that the cracking/mushrooming of the strut mounts is what is cause my problem???
Old Aug 16, 2012 | 06:28 AM
daflake's Avatar
daflake
Hard to say what is causing it. Since they are cracked, there is a possibility that this is causing the problem. I would get the fixed and see what happens.
Old Aug 18, 2012 | 06:49 PM
squonkvt's Avatar
squonkvt
When I got my 2002 a couple weeks ago, same thing was happening. The dealer has the struts replaced but didn't do the mounts. Mechanic who put in mounts check the rear struts and one was messed up and the tire was just beginning to show signs of cupping. Fixed rear, new front mounts and all is good.
Old Aug 19, 2012 | 06:50 AM
STF_U's Avatar
STF_U
I replaced the cracked strut mounts and all is good, it would appear that was the cause
Old Aug 20, 2012 | 05:33 AM
minsanity's Avatar
minsanity
Hope you flattened back the strut towers before you replaced those cracked mounts & installed some reinforcement plates.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
