Navigation & Audio Zune skipping while plugged in?
Old Aug 10, 2012 | 07:37 PM
Andrew_C's Avatar
Andrew_C
Got my '13 Justa Cooper today and love love love it except that for some reason while I'm charging my Zune via USB in the console, music skips every few seconds. Unplugging it brings it back to normal.
I'm a bit perplexed and don't really like either option of not charging it or dealing with the skipping.
Also a slight change in the 2013s; if anyone cares, they moved the aux/usb inputs to the bottom of the console where there used to be a spot for a little tray. The black box in the upper corner of the bottom of the console is still there for some reason though.
Old Aug 10, 2012 | 08:42 PM
Melangell's Avatar
Melangell
Zune??????
Old Aug 10, 2012 | 09:44 PM
rkw's Avatar
rkw
Andrew_C,
Are you plugging it into just USB, or both USB and aux at the same time? If both, there is potentially ground loop noise that could interfere with electronics. You could try a ground loop isolator like this:
Amazon Amazon
Melangell,
Zune never caught on, but have you ever actually tried one? I haven't, but I know that the later versions had good reviews and it has its fans. I just don't see the humor.
Old Aug 10, 2012 | 09:47 PM
Melangell's Avatar
Melangell
Sorry....Zune, seriously? I DO have to give credit to a diehard!
Old Aug 10, 2012 | 10:27 PM
Btwyx's Avatar
Btwyx
Is that a Zune with a hard drive? Is the car moving when it does it? Getting hard drive based music player to play while being jostled is tricky, I don't know how well a Zune would cope with that.
Old Aug 10, 2012 | 10:28 PM
Melangell's Avatar
Melangell
Zune.......
Old Aug 11, 2012 | 04:59 AM
Andrew_C's Avatar
Andrew_C
My little red Zune rocks and rolls just fine thank you very much!
They have the same hard drive as most iPods and it plays perfectly fine when it's not plugged in via USB so I know it's not a jostling issue. I actually forgot to bring my USB cable when I was driving it home from the dealership last night and had no problems jamming out until I got home and plugged it in for an in town stroll; then it started skipping a bit.
Yes, I am using both the aux input and the USB so I guess I'll grab that adapter and see if it fixes the issue.
Old Aug 14, 2012 | 04:56 PM
sbeezy's Avatar
sbeezy
It's probably skipping because the HU keeps trying to index it or can't find the protocol to use it.
Old Aug 16, 2012 | 10:11 AM
rkw's Avatar
rkw
That's a good point. If you wanted the USB only for power, you could instead use a
USB power adapter USB power adapter
in the cigarette lighter socket.
Old Aug 16, 2012 | 08:24 PM
Andrew_C's Avatar
Andrew_C
Originally Posted by rkw
That's a good point. If you wanted the USB only for power, you could instead use a USB power adapter in the cigarette lighter socket.
I'd use that but I'm charging my phone via the cigarette lighter socket! Maybe I could swap the two?
Old Aug 16, 2012 | 11:28 PM
rkw's Avatar
rkw
The adapter I linked has dual USB ports that would charge both, or you could try swapping.
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Jun 28, 2016 08:58 AM
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 03:56 PM
