Stranded! Threw belt in Newark nj. Help
Old Aug 10, 2012 | 04:39 PM
scatpack's Avatar
scatpack
Never mind
Never mind.
Old Aug 10, 2012 | 05:22 PM
slinger688's Avatar
slinger688
Originally Posted by scatpack
Im currently stranded in Newark nj! Gulp
Battery light went on in slow traffic. And I could smell something. Temp was normal. Engine stumbled and temp shot up and I went into limp mode. I got off the highway and the cool fan was going and the smell of rubbber
I can see a shiny pulley so I must have lost a belt. I let it sit and started it up. I get the 1688 code and I'm able to drive it I turned ac off with the hopes it was just that but I'm not sure. I'm parked in a lot but not sure if ishould attempt 23 mi ride home
There's a mini BMW tuner in Newark. but I have no contact info for him. Closest dealer is 24 miles
Thoughts?
AAA tow truck.
And prestige mini is in mahwah NJ and morristown mini is also close.
Old Aug 10, 2012 | 05:24 PM
Eric_Rowland's Avatar
Eric_Rowland
Definitely don't drive 23 miles. Belt drives the alternator, AC and SC.
Belt install isn't overly complex, but you do need to compress the pulley tensioner. There is a special MINI tool for this, but you can use about any 2-3' long metal rod.
Here is one DIY method.
Old Aug 10, 2012 | 05:29 PM
Braminator's Avatar
Braminator
Drives the waterpump also. Don't drive it and risk major damage from overheating.
Old Aug 10, 2012 | 05:41 PM
scatpack's Avatar
scatpack
Anyone have a belt diagram so I can which one is off?
Old Aug 10, 2012 | 05:43 PM
dubstepsteve's Avatar
dubstepsteve
do you still have the old belt? maybe you can tape it back together?
Old Aug 10, 2012 | 05:52 PM
scatpack's Avatar
scatpack
No flashlight!
Old Aug 10, 2012 | 05:53 PM
dubstepsteve
use your iphone?
Old Aug 10, 2012 | 06:00 PM
NightFlyR's Avatar
NightFlyR
If you dont know what you are doing, being stuck on a road at night in a place that is not exactly known for being safe , I would get it towed ,its the best thing to do. Why risk your self trying to fix your car on the side of the road.
Old Aug 10, 2012 | 06:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sounds like your crank pulley came apart. Time to the get the ATI damper.
Old Aug 10, 2012 | 06:55 PM
ERIK06MCS's Avatar
ERIK06MCS
If you tossed the belt and do not have a tensioner stop I'd be zhocked if the tensioner didnt crash into the crank pulley too.
Sounds like you alreaxy drove it a bit stuck in traffic. Sure hope you didnt overheat. I hope taping it was a joke. Duct tape wouldnt even hold it together against the strength of the tensioner.
I would hope you have roadside/tow coverage on your insurance!
Old Aug 10, 2012 | 07:09 PM
dubstepsteve
hmm..would elmers glue would hold up?
Old Aug 11, 2012 | 07:00 AM
scatpack's Avatar
scatpack
We'll now in the daylight I can see... I didn't lose the belt. It may be slipping though.
Code 1688. First sign was the battery light on in idle in traffic
Old Aug 11, 2012 | 08:39 AM
slinger688's Avatar
slinger688
Can you drive?
Old Aug 11, 2012 | 09:04 AM
scatpack's Avatar
scatpack
Rather than risk it. I had it towed to morristowm mini. Waiting for the diagnosis.
Thanks everyone of their help.
Old Aug 11, 2012 | 09:50 AM
scatpack's Avatar
scatpack
Ugh. Morristown is pulling the "let's replace what code 1688 in the manual tells us". Not belts
Ecu
That would cause the burnt rubber smell??
Old Aug 11, 2012 | 10:53 AM
scatpack's Avatar
scatpack
Convinced them to take another look.... Broken balancer. And leaky thermostat housing (recall?). $1400 before taxes.
Old Aug 11, 2012 | 01:23 PM
slinger688's Avatar
slinger688
Ouch. Hope they would work out a deal with you.
Old Aug 11, 2012 | 05:50 PM
NightFlyR's Avatar
NightFlyR
That is alot of coin, I just had my balancer, water pump, theromostat, belt, and housing replaced, plus they put in my rebuilt supercharger for under 1200. I had this done in Denville and my car has never run so good.
Old Aug 11, 2012 | 09:23 PM
ERIK06MCS's Avatar
ERIK06MCS
Recall on the tstat housing- havent heard of that one. Perhaps a technical service bulletin. Either way this place rubs me the wrong way by the sounds of things. Not sure how they thought it was a bad ecu when Way knew 1000 miles away even that this was gonna be a balancer issue, lol. Honestly, the banacer can be replaced by any ham fisted gorilla in about an hours time with simple tools. If you have them do it, I would Seriously consider buyimg either of the fluid/gel filled dampers that Way sells on his site. Its very common for the Oem damper to fail, but Ive never heard of an ATI failing..
Also, ask about the leak. If theyre quoting it because they see dried crust coming from that area or wetness like seepage then its not an immediate concern. If its dripping out of the housing or the housing is cracked and you're loosing coolant to the ground then by all meams, address it before you overheat.
Either way, thats a steep price and starting off by quoting an ecu it doesnt instill much confidence. I sure hope you can get back on the road and motoring soon though!
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
