AP Racing Big Brakes on JCW
Old Mar 21, 2004 | 05:27 PM
ftbt's Avatar
ftbt
I installed a set of AP Racing 4 Pot Caliper Big Brakes on my JCW yesterday, along with cross drilled rotors, Goodridge stainless steel llines on the front and back and Motul racing fluid. (Unfortunately, the distributor messed up and gave me 2 sets of front rotors instead of a set of front and rear rotors, so I'll have to install the rears tomorrow.)
Wow! After bedding in the brakes today, I certainly noticed a big difference over stock. No pedal softness and instant grip. The font pads are Jurids (OEM for Porsche and Mercedes) and designed for street and light track. Still have the original rear pads on the original rotors. I'll probably go with Ferodo 2500's on the rears, if they are available (when I get the rotors).
I sort of went back and forth between Brembo - Stoptech - AP. My guess is that they all are good ... but AP turned out to be a lot brake for the $$.
Here's a look:
ftbt
2002 Works Cooper S, Sn. 1165, DS/W; Sport + Premium + Alta CAI + H Sport Springs, Competition Front & Rear Sway Bars, Rear Camber Control Arms + 17" Team Dynamics Pro Race 1's; 215-45-17 Kumho MX's + AP Racing Formula Big Brakes, XDrilled Rotors, Goodridge SS Lines + Clear Bra + Schroth Harness and a full tank of 100 octane ... life is good!
2002 CVT Cooper LY/W + Sport + 17" S Lites & Pirelii Euforias + Clear Bra
[img]null[/img][img]null[/img]
Old Mar 21, 2004 | 07:23 PM
ftbt's Avatar
ftbt
Sorry. Here are the pics again:
http://www.mini2.com/forum/attachmen...chmentid=33017
http://www.mini2.com/forum/attachmen...chmentid=33020
http://www.mini2.com/forum/attachmen...chmentid=33021
These should work.
ftbt
Old Mar 21, 2004 | 07:45 PM
XAlfa's Avatar
XAlfa
Well, they definitely LOOK good. What was the total price for all 4 corners?
Old Mar 21, 2004 | 07:58 PM
ftbt's Avatar
ftbt
Big brake kit, rear rotors, lines, fluid, tax and installation ... around $2,200.00.
ftbt
Old Mar 22, 2004 | 09:21 AM
ubercooper's Avatar
ubercooper
The AP Racing site did not list the mini in its fitment guide. Which kit were you able to fit? Which distributor did you use? I am of course trying to do the impossible and find brakes that will fit under my 16" SSR Comps
Old Mar 22, 2004 | 09:37 AM
dandp's Avatar
dandp
FYI - Tar- Ox makes a BBK that will fit under 16" wheels.
ftbt - I am assuming you did not need spacers for the front, correct?
Old Mar 22, 2004 | 09:38 AM
dandp's Avatar
dandp
nice looking setup BTW!
Old Mar 22, 2004 | 01:00 PM
ftbt's Avatar
ftbt
If you looked on AP's site and came up empty-handed, you were probably looking at the "Competition" line rather the "Formula" line. There is a fitment guide for MINIS under the Formula line. The part number of the MINI caliper is: CP7611. If you are in the US, you might want to call Stillen/Brake Pros, the AP distributor in Costa Mesa, California. The number is: 800-431-3373. Mine fit fine with my Team Dynamics Pro Race 1's -w- a 45 mm offset. No spacers needed. There is about a 1/2 inch from the face of the caliper to the wheel.
ftbt
Old Mar 22, 2004 | 08:40 PM
ftbt's Avatar
ftbt
The AP distributor (Stillen/Brake Pros) gave me the correct rear rotors this afternoon (x drilled and slotted) and they even installed them for me while I waited at no charge. I bedded them in .... and yes .... there is a difference with the whole new front/rear brake set-up! Initial impressions with the whole set-up: Good bite/grip, shorter stopping distances & firmer pedal. I think things will even get a little better when I replace the original pads with some Ferodos. Can't wait to do some serious canyon carving ... last time I did, I experienced the dreaded brake fade ... not a good thing.
ftbt
Back to top
Old Mar 22, 2004 | 09:05 PM
2perCooper's Avatar
2perCooper
when you were doing your research for the BBK. did u find out which type of 17" wheels would fit over each? i read that a +45 offset would work perfect with either the stoptech or the ap racing BBK.
btw, lookin good and where did u get those black lug bolts?
thanks
-chris
_________________
Mods: tint (35%)
Soon to be Mods:
black aero grills,
Enkei RPM2 17"
Old Mar 23, 2004 | 06:50 AM
ftbt's Avatar
ftbt
I only checked with the wheels that I was going to buy, namely the Team Dynamics Pro Race 1's. What you can do though is to go Stop Tech's site and download the wheel template that they have and use that as your guide. Basically, if the wheels you want will work the Stop Tech kit, then, in all likelihood, they will work with the Brembos.
The car came with the black lug nuts.
ftbt
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
elightbo
Aug 17, 2015 01:50 PM
nomar116
Aug 10, 2015 11:24 PM
