R56 Trying to understand difference on several parts, Justa vs S
Old Jul 22, 2012 | 05:48 PM
epanarese's Avatar
epanarese
First - brake calipers: are they any different on the S and Non-S R56?
Second - clutch
Third - springs
Thanks!
Old Jul 22, 2012 | 05:57 PM
dannyhavok's Avatar
dannyhavok
I believe the S does have bigger brakes. Someone will correct me shortly if I am wrong.
The S has a dual-mass flywheel, the base doesn't.
The springs are the same unless the S is equipped with Sport Suspension, which was/is also available on the Base.
Second - clutch
Third - springs
Thanks!
Old Jul 22, 2012 | 07:12 PM
epanarese's Avatar
epanarese
Thanks! So is the actual clutch assembly the same?
Can someone confirm that the calipers are the same?
Old Jul 22, 2012 | 07:19 PM
bluefox280's Avatar
bluefox280
If you check against RealOEM.com and PenskeParts.com, you'll see that the front calipers are the same.
HOWEVER, the front carriers and rotors are different between the Justa (280mm) and 'S'-models (294mm).
The clutches ARE different between the Justa (200mm) and the 'S'-models (228mm).
Springs are unconfirmed to be the same as MINI doesn't provide rates.
But, the suspension components used (strut, bump stop, spring plates) are the same between both the Justa and 'S'-models.
- Erik
Old Jul 22, 2012 | 07:21 PM
epanarese's Avatar
epanarese
Interesting, thank you! Surprised the clutches are different given the same motor dimensions and same transmission.
Old Jul 22, 2012 | 07:28 PM
bluefox280's Avatar
bluefox280
...the same motor dimensions and same transmission.
False; the transmissions are DIFFERENT between the Justa and 'S'-models.
- Erik
Old Jul 22, 2012 | 07:33 PM
epanarese's Avatar
epanarese
Ah, another good thing to know! Do the differences go beyond gear ratios?
Old Jul 22, 2012 | 07:41 PM
bluefox280's Avatar
bluefox280
Yeah, the transmission housing is different between the two regards to mounting hardware and size of the housing.
- Erik
Old Jul 22, 2012 | 07:46 PM
epanarese's Avatar
epanarese
maestro39
Oct 27, 2015 02:38 PM
elightbo
Aug 17, 2015 01:50 PM
Aug 12, 2015 01:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
