R50/53 Wheel Spacers Question!!
Old Jul 10, 2012 | 03:31 AM
LethalR53's Avatar
LethalR53
Greetings!
I have a 2004 cooper S, with S-Spokes 17" and stock suspension and brakes. Just got off the phone with MINI parts department and they have a set of brand new R95's :D ! Wondering what size wheel spacers to use on the R95's? I don't want anything too extreme, just want it to sit nicely. And should I use wheel spacers only in the front, or on all four wheels? Thanks!
Old Jul 10, 2012 | 02:32 PM
quikmni's Avatar
quikmni
I believe that the R95 wheels are 18 x 7" with a 52mm offset. If that is correct you should be able to use 15mm wheels spacers without a rubbing problem with stock suspension. But that will depend on what tire size you use.
I use 18 x 7 et 52 with 15mm spacers using 215/40-18 tires on my 2006 MCS with JCW springs (lowered about 5/8"). I had slight rubbing in the rear wheel arch that was resolved with a little plastic trimming. Thus withoout lowering you should be fine with 15mm spacers.
I also notices that someone was selling 12mm spacers that will of course work with even less chance of rubbing.
Old Jul 11, 2012 | 06:59 AM
pilotguy1050's Avatar
pilotguy1050
Does anyone have any before/after photos of what these changes look like on a car?
Old Jul 11, 2012 | 08:46 AM
quikmni's Avatar
quikmni
Here is a NAM link where I had previously posted some pictures.
https://www.northamericanmotoring.com...-question.html
I run about -2.0 degrees of camber in the front and about -1.5 in the rear. Thus that tilts the front tire in a little more than stock.
Old Jul 12, 2012 | 09:07 AM
pilotguy1050
What is the purpose of tilting the tires/wheels in like that? I would think it would promote poor tire wear on the inside of the treads?
Old Jul 12, 2012 | 09:30 AM
quikmni's Avatar
quikmni
Negative camber, tires look like this / \ from front, provides better handling but it can increase tire wear depending on how you drive the car. If just easy driving than tires will wear inside edge a litte faster. If you drive hard in canyons (corner hard) the negative camber might actually improve tire wear.
With negative camber, when you drive straight the tires ride on the inside edge but when you turn the tires flatten out across the road providing a better contract patch.
With zero | | camber the tires ride flat when going straight but go on the edge when cornering thus reducing the contact patch.
For people that do a lot of cornering with zero camber, they will see the outside edge of the tires wear faster due to cornering on the edge of the tire. Thus, for those people that corner a lot some negative camber improves the tire wear and handling.
Old Jul 12, 2012 | 10:27 AM
pilotguy1050
<snip>
That makes sense... I forget sometimes that not all of us are named "Melvin Milquetoast" and drive aggressively. I have seen the rear tires like that / \ on lots of Porsches, and thought they just all had crappy suspensions or bad wheel bearings.
G1HQ
Dec 7, 2015 02:23 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
ki7hy
Aug 12, 2015 07:07 PM
ti22fjc
Aug 9, 2015 05:49 PM
