Desparate need of quick wheel & tire advice! Too agressive?
Old Jul 5, 2012 | 12:47 PM
dclaw312's Avatar
dclaw312
Can I pull this set up off without it being too aggressive or ridiculous poke and/or rubbing? I have 2007 Cooper S and I was going to go get them if I could get some affirmative answers. Thank you, everyone.
16x9 +15 offset
205/45/16
http://columbus.craigslist.org/pts/3118479759.html
Old Jul 5, 2012 | 12:51 PM
JP Money's Avatar
JP Money
I would vote no but I'm a bit conservative on these set ups. I'm sure someone will chime in with more experience on the extreme side of things.
Old Jul 5, 2012 | 01:00 PM
aklucsarits's Avatar
aklucsarits
Use a wheel offset calculator like this:
http://www.1010tires.com/WheelOffsetCalculator.asp
VS a factory 17x7 +43mm fitment, the wheels you are looking at will stick out from under the fenders by about 2 inches... So no, not even close to fitting.
Old Jul 5, 2012 | 01:07 PM
dclaw312's Avatar
dclaw312
I thought the factory was ET48, or does that not even matter?
Old Jul 5, 2012 | 01:11 PM
dclaw312's Avatar
dclaw312
I'm not trying to go crazy, I just wanted flush or SLIGHT poke. I live downtown, so I can't be stupid.
Old Jul 5, 2012 | 02:12 PM
Creeve's Avatar
Creeve
Yes they will poke a lot.
16x9 et25:
8" wide et30 or 35 is about as flush as it gets:
Old Jul 5, 2012 | 03:03 PM
dclaw312's Avatar
dclaw312
I appreciate it. I guess I'm going to do a 7.5'' ET35 with spacers. How wide of spacers can we run on that set up before extended lugs are called for?
Old Jul 5, 2012 | 08:55 PM
bluefox280's Avatar
bluefox280
Any spacer you run should correlate with the same extended length of lug bolt.
So for example, if you're running a 10mm spacer, you're needing a lug bolt that's 10mm longer than OEM.
- Erik
Old Jul 6, 2012 | 02:53 AM
slinger688's Avatar
slinger688
Are you lowered?
Old Jul 6, 2012 | 04:22 AM
dclaw312's Avatar
dclaw312
Not yet. I was still deciding if I was going to do air or coils. I've searched for extended lugs on here and have found mixed suggestions- does anyone have personal experience with a particular brand or know the difficulty of install?
I know with my G35 I bought extended lugs from what was perceived to be the "authority" on 350/G35's(Z1), but the threads were rubbish and the metal was shotty.
Old Jul 6, 2012 | 05:14 AM
slinger688's Avatar
slinger688
I would go conservative if you are thinking of lowering. A mm here or there will cause rubbing. Also the back has a metal lip that can cut your tire.
pre shrunk
Aug 18, 2015 11:09 AM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 9, 2015 09:42 AM
