R60 Instructions for Removing Tail lights & rings
Old Jul 4, 2012 | 12:54 PM
Mini-b10's Avatar
Mini-b10
Hey everyone...I have searched the sites and can not find any instructions or help ideas in how to remove the rear turn signals so I can replace my trim rings. Can anyone point me in the right directions for instructions or let me know how or what to remove to get at the lights? Thanks.
Old Jul 4, 2012 | 03:33 PM
cursor718's Avatar
cursor718
i have a few pics here...
https://www.northamericanmotoring.co...tallation.html
Old Jul 5, 2012 | 04:40 AM
Mini-b10's Avatar
Mini-b10
Thanks for the pics but I guess what I should have asked about is what parts of the panels inside do you have to pull off and how to get at the lights? Thanks.
Old Jul 5, 2012 | 07:44 AM
cursor718's Avatar
cursor718
this is the only panel i took off
http://www.flickr.com/photos/59240565@N04/7508161234/http://www.flickr.com/photos/59240565@N04/7508161234/ by http://www.flickr.com/people/59240565@N04/, on Flickr
Old Jul 5, 2012 | 10:26 AM
Mini-b10's Avatar
Mini-b10
Great!!! I just pulled them and checked it out. At least now I have access and I can begin bitching tonight trying to get at those bolts. Thanks cursor.
Old Aug 11, 2013 | 06:50 PM
EHans's Avatar
EHans
Originally Posted by cursor718
FYI - I wrote up some more detailed instructions in that thread here. Those pics were helpful, but didn't tell the whole story, at least not for me. I'm not super mechanically inclined. I can figure it out in my head, but applying to reality isn't as easy.
Old Jul 11, 2015 | 02:36 PM
Mikesall4's Avatar
Mikesall4
Found something new
While is was replacing the trim rings on my R60, and reading alot about how to do it, I notice the rear light assembly is very easy to put back.
In looking at the clips that keep the light assembly in place are pressure clips. So after removing the outer clips to take it off, put the clips back on and tighten before putting it back. Use your hand or a rubber mallet to smack it back in place. The lights are secure and I hosed them down but no leaks.
Old Jul 14, 2015 | 05:58 AM
+1 https://www.northamericanmotoring.co...ml#post3790292
Thanks for the update Mike
The blackline or chrome trims can be a little work and have those tabs on the back.
https://www.ecstuning.com/b-genuine-mini-parts/rear-taillight-black-surround-set/63129812631kt/
Old May 3, 2017 | 11:49 AM
Shane Wendel's Avatar
Shane Wendel
It's pretty easy to do if you have one of these:
Amazon Amazon
With a socket adapter and an 8MM deep socket. That upper-inner one is still a pain, but doesn't require as much contortion. I do recommend tying a string or something to the driver though, just so you can pull it out if you drop it. I dropped it once and had to use a magnet snake to get it out.
Old May 5, 2017 | 10:21 PM
bmwr606's Avatar
bmwr606
this is the tool needed
Attached Thumbnails Instructions for Removing Tail lights & rings-20150913_090420.png
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
dyeLucky
Aug 7, 2015 07:10 AM
