mini countryman door rattling noise *solved*
Old Jun 17, 2012 | 05:33 PM
worrynot's Avatar
worrynot
Hi Guys,
For the last two weeks I have been slowing going insane with the a rattling noise coming from the drivers door. This weekend I took the door apart trying to found the source of the rattling.
I couldn't find anything inside the door, so I took a trip out to some rough road and did a number of tests.. the rattling only happens with the windows up.
Appears there is some worn area up under the rubber seal that puts glass against metal. You can find this by running your fingers along the entire seal, your finger will feel smooth all the way along, if you hit a rough spot, you found it... the source of rattling.
Once I found the rough parts, I cut some tape (I do not recommend using electrical tape as the adhesive on electrical tape breaks down quickly), I used gorilla tape.
Measured to size before putting under the lip/seal.
And placed under the seal, you can't see it straight on - I took this image looking up into the seal.
Rattling gone.
Good temp fix until I can make a trip from San Antonio to Austin MINI to have them fix the seal properly.
Hopefully this helps someone else who is going crazy trying to stop the rattling. Not sure if this voids the warranty (so use at your at our risk).
Old Jun 17, 2012 | 06:24 PM
shark715's Avatar
shark715
Thanks for taking the time to post. Bet there's someone else out there who will benefit from this.
Old Jun 17, 2012 | 06:59 PM
stripesace's Avatar
stripesace
Do you not trust Mini of SA?
Old Jun 17, 2012 | 07:06 PM
worrynot's Avatar
worrynot
Nope, service department burned me too many times.
Old Jun 21, 2012 | 08:05 PM
Mauro Sciaccaluga's Avatar
Mauro Sciaccaluga
Hi,
I confirm.. I come at the same conclusion yesterday since I noticed that when I pulled down a bit the window there was no rattling noise at all... But thanks for your home-made solution, I will try it. bye
Old Jun 21, 2012 | 08:31 PM
anthonyhins's Avatar
anthonyhins
same problem happen to my Cm. But i send it back to services center
Old Nov 26, 2012 | 02:43 PM
hell0kitty's Avatar
hell0kitty
My 2012 Countryman had a loose strike plate in the driver's side door that was making quite a bit of racket.
Old Aug 6, 2013 | 07:01 AM
yellow05mcs's Avatar
yellow05mcs
Worked like a charm, rattle was driving me nuts, thanks for posting
TREX
Nov 2, 2019 07:31 PM
dyeLucky
Sep 11, 2015 10:41 AM
dyeLucky
Aug 7, 2015 07:10 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
