Navigation & Audio Noisy input?
Old Jun 14, 2012 | 09:41 AM
MCJoe's Avatar
MCJoe
Noisy input?
I connect my iPad through the MINI Y-cable, and it is extremely noisy/hissy. I play the music loud enough that it is not noticeable during the songs, but between songs it is really bad. Am I doing something wrong, or does everyone have this issue?
Old Jun 14, 2012 | 10:02 AM
ZippyNH's Avatar
ZippyNH
Check to see if the noise is present when the item is playing on battery power....some adaptors make a bit of a hum/buzz...trying a different car adaptor may help.
Old Jun 14, 2012 | 10:34 AM
MCJoe's Avatar
MCJoe
Not sure what you mean by 'playing on battery power' - do you mean when it's not plugged into the input?
Old Jun 14, 2012 | 10:39 AM
ZippyNH's Avatar
ZippyNH
Not plugged into a 12v adaptor...
Some folks had a similar buzz on gen1 cars the aux in jack if the phone was also charging.
Old Jun 14, 2012 | 10:42 AM
MCJoe's Avatar
MCJoe
The Y cable has a USB part and an AUX part. It won't play without both plugged in.
Old Jun 14, 2012 | 03:28 PM
staynedglass's Avatar
staynedglass
make sure that the headphone part of the y cable is pushed in all the way. i've had the same issue with mine and it turned out to not be completley seated.
Old Jun 20, 2012 | 04:31 PM
CountryStyle's Avatar
CountryStyle
I had the same problem with my XM skydock and I installed a 3.5 mm ground loop isolator and it fixed the problem. (7 $ on ebay)
Old Jul 13, 2012 | 01:39 PM
MCJoe's Avatar
MCJoe
My 3rd gen iPod does not have the same issue, only my iPad.
Old Jul 23, 2012 | 05:59 PM
Ragnar4841's Avatar
Ragnar4841
Dumb question, but is the iPad volume turned way down?
eliseo1981
Nov 2, 2015 11:24 AM
eddyjoe
Oct 1, 2015 05:09 PM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
