R56 Mystery Button
Mystery Button
I am the proud owner of an 07 MC with a button on the dash I have not been able to figure out. It is to the left of the steering column and shows a light with (it looks like) a number "2" on it. It has a tiny green LED that glows after I press it but I can't tell that turns any lights on; any ideas?
Thanks!
Thanks!
Thanks Guys, I have the factory bumper mounted fog lamps that are controlled by a center toggle. I'll try the button with the high beams per Drobinson's suggestion. Thinking about going outside in my underwear to try this out.
not sure if you have a manual as you purchased the car. Of course if you had one it would not have helped you with this particular switch as it is not listed in the owners manual. but here is a link to the manual for you anyway.
http://www.motoringfile.com/files/2007_MINI_Hardtop.pdf
Here are the install and use instructions for the Auxilary Lights that you have on your car. page 16 is where the use instructions start. Note: in the use instructions they use the term "headlight main beam" that refers to what americans call "high beams"
http://www.motoringfile.com/files/R56_aux_lights.PDF
Thanks Everyone, that was it. I probably never would have figured that out
Thanks Schatzy for the Auxiliary Light Manual: it looks like I need to change a bulb, have had the covers on for quite awhile and didn't notice one was out!
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
F55/F56 Do I have rear fog lights?
Peking Duck
Jan 19, 2021 03:17 AM
Navigation & Audio Installing the PAC SWI-RC Steering Wheel Control Interface
Filmy
Jun 28, 2016 08:58 AM
misterbl
Sep 16, 2015 11:22 AM
