Suspension Camber plates for an 07 cooper
Old Jun 11, 2012 | 03:17 PM
07hardtop's Avatar
07hardtop
Noob with suspension questions
Going to be placing an order in the next few days for nm engineering springs and 22mm rear sway bar, bump stops, and camber plates.
My issue is i do not know which camber plates to buy, Vorshlag, Ireland, or Eibach.
From my research on the forums seems that everyone regards vorshlag as the best, but they are also over $400
What is everyone on here running? Opinions on the brands? etc
And what is a good camber setup? I see that about -1.8-2 front and about -1.5 rear seems to be common?
I autocross a few times a year, but the real abuse to my car comes from my 80-120 mile commute to work/school so i need parts that will last as long as possible.
one last question Are the Powerflex Rear Upper Shock Mount Bushings worth installing?
Thanks in advance for any help
Old Jun 11, 2012 | 03:31 PM
bahawton's Avatar
bahawton
I just installed Eibach/SPC plates & they raised the car approximately 1/3".
I could get 2 degrees negative camber on each side once I pounded the metal rib on the driver's side strut tower flat.
I run 16" tires with Koni FSD shocks & JCW springs and was surprised to find the Eibach/SPC plates make the dash & doors rattle a more on certain roads. I would hate to see how much NVH a spherical bearing plate transmits!
Old Jun 11, 2012 | 05:49 PM
mbwicz's Avatar
mbwicz
I have the IE fixed plates on my car, along with TSW springs. I am running about 2.0 in the front and 1.0 in the rear for my 40 mile commute. The IE plates are made like the factory ones, with some isolation between the strut mount and the body mount. The higher end units (like the vorshlag) are spherical joints, which are more precise but can transmit more NVH.
I did not change the upper shock bushings. It did seem to tighten up the car when I replaced the rear control arms. My best mod is the accessport, though....
I am very happy with my setup. I don't plan on tracking or autocrossing my car, especially with the all season tires that came on the wheels.
Have fun,
Mike
Old Jun 12, 2012 | 12:02 PM
CalsonicSE's Avatar
CalsonicSE
The Vorshlags are $439 but will be $500 once you add $35 for the oem style spring perch (required for your TSW springs), shipping, and a ball hex wrench (helpful for adjusting camber plates on a MINI). Vorshlags are expensive, but are very high quality, very durable, have the best feel on the track, do not raise ride (the plate stack is actually a few mm shorter than stock), and work with different springs types.
I had ordered the Vorshlags, but Vorshlag wanted me to first remove one of my Bilstein HD struts to confirm several measurements before they could ship. I decided it was more trouble than I wanted to deal with, so I recently ordered the IE fixed plates instead and saved myself $300. I'm currently at -0.8 (w/free camber mod) and hope to get around -2.0 after the IE plates.
Getting the IE plates was probably the logical choice for me as the car probably can't get much more than -2.0 camber in the front anyway running on stock springs, even with the adjustable Vorshlags.
Old Jun 12, 2012 | 12:14 PM
countryboyshane's Avatar
countryboyshane
Vorshlags are the only options. There truly is no comparison to the adjustability, quality & workmanship, and durability of them. I ran the gauntlet of trying to decide between brands but you'll always come back to Vorshlag. They are simply fantastic.
Old Jun 12, 2012 | 12:39 PM
07hardtop's Avatar
07hardtop
called wmw yesterday for his suggestion, vorshlag was the answer for quality and durability, also suggested the 25.5mm H-sport competition sway bar instead of the 22mm nm engineering. It has the same strength as the 22mm but only weighs 5 lbs and is significantly cheaper
Thanks for the input
Old Jun 12, 2012 | 12:40 PM
andyroo's Avatar
andyroo
For someone not planning on tracking their car or autocrossing extensively, I'd skip the Vorshlags and get the IE fixed camber plates. Simple, durable, and no NVH. And a good price.
Skip the rear shock bushings too.
- Andrew
Old Jun 12, 2012 | 12:54 PM
07hardtop's Avatar
07hardtop
Ive heard a few people that have seen the ie plates completely fall apart, really dont want to have to worry about that.
And my autocrossing is only limited by my work schedule, id go to every local event (which is almost every weekend) if i could.
Old Jun 12, 2012 | 01:08 PM
andyroo's Avatar
andyroo
The IE fixed plates are great, the adjustable ones not so much.
This post references the major problem I have with Vorshlags with regular struts. But great plates for coilovers.
http://www.*********************/for...#axzz1xbyDkpSE
- Andrew
Old Jun 15, 2012 | 11:04 AM
DOC4444's Avatar
DOC4444
20K on IE fixed. No problems so far.
DOC
Old Jun 16, 2012 | 10:36 AM
DVUS CPRS's Avatar
DVUS CPRS
Talk about just the thread I was about to start!
I was wondering whyh the R56 seems to have +camber at full lock on the outside wheel. I've never seen a car designed like this.
Either way, who sells the IE fixed plates, and how much -camber can I expect? I don't so much that I'm wearing down my new tires prematurly. There won't be any autoX going on with me. Our roads are an autoX event in themselves! I can feel the car wanting to slip as I enter a tight turn at speed though, so a bit more -camber would help.
Old Jun 16, 2012 | 02:12 PM
07hardtop's Avatar
07hardtop
Waymotorworks sells the ie fixed plates/adjustable plates as well as the vorshlag and eibach adjustable camber plates.
My issue with fixed plates is they are exactly that, fixed as well as dont offer a large increase in negative camber.
Old Jun 16, 2012 | 02:43 PM
Eddie07S's Avatar
Eddie07S
The fixed plates are stronger than the stock mounts. These are great for road and occasional autoX use. Also, for autoX ditch the stock wheels and get something with a 38 to 42 mm offset. Next best improvement I made for autoX.
-0.3 to -1.6 is not a big change?????? You can only get -2 deg with the stock springs so there little to be gained by adjustable plates. So for occasional autoX and a lot of highway use, these should be ideal. Also anything must more than -2 deg will start to chew the tires up.
Old Jun 16, 2012 | 03:33 PM
DOC4444's Avatar
DOC4444
I would strongly suggest starting with the specs in my sig. I have 22K miles of aggressive street driving on the current tires. I rotate religiously every 3K and run 31 psi rear and 33.5 psi, front, cold and have perfectly even wear across the face of the tread of each tire. I arrived at the alignment and pressure settings by using the same tire pyrometer I use to tune my Formula Ford racing cars.
This is important because if you have anything that is slightly different, you may need to make adjustments, but my setup should get you close to start. Much more negative than -2 degrees will probably really eat up the insides on the street. You should be able to get that much with the fixed IEs on an MCS.
With the range of adjustment available with the rear bar, I can go from mild understeer to mild oversteer, as I wish.
BTW, if you remove the plastic pins and use the fixed IEs, there is a good range of adjustment. Anything with spherical bearings will pound out and eventually rattle within a few thousand miles. These kinds of joints are for racecars where you routinely change them in less than 2K miles.
DOC
Old Jun 16, 2012 | 06:11 PM
DVUS CPRS's Avatar
DVUS CPRS
Can I still keep my NM FSB with the use of fixed or adjustable camber plates? Also, the IE plates say for use with stock springs, does that mean any other lowering spring as well, as long as the perch size is the same?
Old Jun 16, 2012 | 09:06 PM
Eddie07S's Avatar
Eddie07S
First - are you talking about the Koni FSBs? If you are, you shouldn't use them with lowering springs (although some people do). There are other posts about the use and application of the FSBs. Do a search to see what is said about them. The IE fixed plates should work with the stock spring perch and stock size/diameter spring.
Old Jun 16, 2012 | 09:09 PM
DVUS CPRS's Avatar
DVUS CPRS
You're thinking of the Koni FSD shocks.
I'm talking about my NM Engineering Front Strut Brace. Will I be able to use any of the camber plates with it?
Old Jun 17, 2012 | 04:20 AM
mbwicz's Avatar
mbwicz
I have a strut brace with my fixed plates, no problems. The IE plates actually have longer studs than the factory ones, so there is minimal concern about thread engagement with a strut bar. I agree with the above comment also that the IE plates are designed for use with the stock spring cup, so any aftermarket springs that are designed for the stock-type struts would work fine.
Mike
Old Jun 17, 2012 | 07:14 AM
DVUS CPRS's Avatar
DVUS CPRS
Thanks for that info mbwicz How's the front tire wear been since installing them, and have you noticed any increased vibration or noise in the cabin?
Mike
Old Jun 17, 2012 | 10:04 AM
mbwicz's Avatar
mbwicz
I am at about 2.0 negative camber, and have not noticed any tire wear on the inside edge after about 4k miles. I did not notice any additional noise in the cabin, these are built pretty similar to the stock ones. I really think that the fixed camber plates are for people like me, who enjoy the car but don't intend on tracking.
Mike
Old Jun 17, 2012 | 10:08 AM
DVUS CPRS's Avatar
DVUS CPRS
So they ARE fixed at 2 degrees. On WMW's site the description says from 1.7 - 2 degrees. I'm the same way. I just want to enjoy some spirited street driving and know that the car's gonna stick like glue and not push at the extreme.
Old Jun 17, 2012 | 10:26 AM
Eddie07S's Avatar
Eddie07S
Sorry 'bout that mix-up.
My JCW front brace fit just fine with the IE fixed plates. As was said, these have longer studs which helps.
Mike
IMHO - these are a great mod for the person who does occasional tracking but still wants a comfortable car as a DD. They provide a reasonable improvement in the "bite" of the front tires without additional tire wear or NAV.
Old Jun 17, 2012 | 10:28 AM
DOC4444's Avatar
DOC4444
The IE fixed plates themselves have no adjustment. When you actually work on your car you will see how the camber is adjusted. Your actual camber range will depend on ride height, whether you use strut top plates and whether you elongate the slots or leave them stock.
So, the IE fixed plates will NOT just give you -2 degrees. You will have to install and see what your actual range of adjustment proves to be.
DOC
Old Jun 17, 2012 | 10:56 AM
Eddie07S's Avatar
Eddie07S
The Gen II strut tower has factory slots that allow for about 0.3 deg of additional camber. The IE fixed plates are stated to provide -1.2 deg of camber. Using the factory slots, you will be able to adjust the camber from -1.2 to -1.5 deg. with the fixed plates installed. But, as noted there is no adjustment in these plates. With that said when I installed mine and had it aligned it came out at -1.6 deg.
Old Jun 20, 2012 | 04:49 PM
modernbeat's Avatar
modernbeat
Originally Posted by DOC4444
...Anything with spherical bearings will pound out and eventually rattle within a few thousand miles. These kinds of joints are for racecars where you routinely change them in less than 2K miles.
DOC
Doc, I take offense that you lump all spherical mounts together and speak about them in absolutes.
We have a customer with Vorshlag plates on his daily with 125k miles on the original spherical bearings that show no wear or knocking. Good bearings with the right specs and used in the right way can last. And that's what makes differentiates a Vorshlag plate from most others.
sabjcw
Aug 14, 2015 07:40 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
