r53 cold start loss of power HELP PLEASE
Old Jun 5, 2012 | 09:18 PM
tripled333's Avatar
tripled333
So i have been having trouble with my 2002 cooper s , it doesnt like to start cold and generally has a loss of power . The loss of power seems to come and go , when its at its worst the engine surges and really struggles .
I have just picked it up from a local mechanic who specialises in bmw who didnt really give me confidence as he diagnosed the issue as the bearings gone in the supercharger ..wahhht .. which i cant see how addresses the cold start issue .He ran some tests and the supercharger is runnning at 15 psi under load ( normal ? ) and the fuel pressure is 47 psi at idle .
The engine will start first time it warm and idles fine .
Im in NSW, Australia so it doesnt get below about 3- 4 degrees celcius .
Also if i only let the engine crank for a second for the first two times it will start the third time .
Is it likey i just need a new fuel pump and filter ?
appreciate the help
Old Jun 6, 2012 | 02:45 AM
HRM's Avatar
HRM
You have to check and replace as needed the plugs and clean/inspect the contacts on the coil first. Basically a tune up has to be done to rule out the obvious.
Old Jun 6, 2012 | 03:44 AM
tripled333's Avatar
tripled333
sorry i should have mentioned i had the spark plugs changed and a new ignition coil fitted which didnt help
Old Jun 6, 2012 | 05:05 AM
minsanity's Avatar
minsanity
Try techron or any good injector cleaner w/ a fresh tank of vPower. That took care of similar issues for me.
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
ludedude
Aug 10, 2015 07:16 PM
