Coil pack and wires bad- MSD Replacement on eBay?
Old Jun 2, 2012 | 01:17 PM
valvashon's Avatar
valvashon
This is an unbeatable price on a replacement coil pack and wires:
http://www.ebay.com/itm/Msd-Spark-Pl...d24de5&vxp=mtr
Has anybody here ever dealt this this guy? Some of the negative feedback is pretty bad, including accusations of counterfeit parts. This makes me a little worried- how would I tell if I got counterfeits?
Thanks-
val
Old Jun 2, 2012 | 04:07 PM
Hound_va's Avatar
Hound_va
What were the resistance values of the wires that you determined were bad?
Old Jun 3, 2012 | 05:00 AM
HRM's Avatar
HRM
The stock wires and coil are a good design and you should stick with them.
Old Jun 3, 2012 | 05:07 AM
ZippyNH's Avatar
ZippyNH
If folks are saying he is selling fake stuff, why chance it?!
there are 2 diffrent style plugs on the coil on gen1 mini's...they are not interchangeable ...
The fact the coil is a pretty common part used on different cars, stocked by several dealers makes me wonder why you would try to save $ by getting junk that might be fake, that you have no recourse if they are bad.....
Old Jun 3, 2012 | 08:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The MSD coil doesn't fit right. Go with the Screamin Demon coil.
And here are some good wires that won't break the bank
http://www.waymotorworks.com/kingsbo...nce-wires.html
Old Jun 4, 2012 | 02:50 AM
daflake's Avatar
daflake
I just bought a set of those Kingsborne and they really are a nice set of wires for the price! I'd highly recommend them. Still running my stock coil pack though and probably will continue to run it.
Old Jun 4, 2012 | 03:32 AM
ZippyNH's Avatar
ZippyNH
Ditto...good wire, good price.
I did switch to the msd...fits ok with the right bolts (not included unless you buy the coil from a mini vendor), and one rubber o-ring spacer. I had heavy corrosion on the coil terminals....but no real change in performance with the msd in all honesty. The msd with brass was a lower mx stock style upgrade (but red)...if a timy bit of hp could be gain with a coil, the screamen deamon would be it....
getting a good deal on fake stuff that might you you straded or impact your performance in a negative way is a false sense of economy....
Old Jun 5, 2012 | 07:11 AM
valvashon's Avatar
valvashon
Got the stock NGK plugs from a local parts store (Roxbury Auto in Seattle- great store if you are in the area) and the Screamin Demon coil and Kingsborne wires from Way. Hopefully this will clear my P2097 code.
Val
Old Sep 17, 2012 | 06:00 AM
newninja's Avatar
newninja
what about these spark wires from NGK?
Amazon Amazon
iggi
18
Feb 9, 2026 01:00 AM
Bublik
Feb 18, 2023 11:09 AM
W0TM8
Dec 19, 2019 07:50 AM
PrimePower
Aug 16, 2015 06:29 PM
yashmack
Aug 15, 2015 10:16 AM
