3rd gear to 2nd gear jerk
Old May 29, 2012 | 10:41 PM
GeorgeCooperS's Avatar
GeorgeCooperS
I started to experience jerking when breaking. Let say when I am at 30 mph and coming up to a stop sign or red light, break normally (not panic stop), when the car slow to about 10 or 5 mph, it will jerk once and than stop to a complete stop.
I have automatic but I am sure it's not the downshifting "jerk" and there is no ABS or any light on the dashboard when this happen.
need help quick im driving 120 miles in the morning and im pretty scared :[
Any thoughts?
i have a 2007 mini cooper non s
Old May 30, 2012 | 08:00 AM
clay44's Avatar
clay44
Have no clue about this so hopefully someone will correct me if i'm wrong. This might help you isolate the issue.
Maybe try braking with only the e brake handle. If the car still jumps then the problem should be the with the transmission. If the car does not jump the the problem should be with the front brakes.
Again not sure if that will help find out whats wrong or not just a thought.
Old May 30, 2012 | 08:05 AM
GeorgeCooperS
I read up some other similar posts and they were saying something about changing their rotors but I don't understand what that has to do with the car doing a hard jerk when it hits 2nd gear
Old May 30, 2012 | 11:42 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'm thinking it's a transmission issue. I think the brake rotors suggestion was about the discs being warped maybe?
-Jorge
888.280.7799 | 6am - 5pm PST
Old Jun 12, 2012 | 12:53 PM
GeorgeCooperS
The problem was with the valve body which is in the transmission gasket so instead of replacing the entire transmission I had a friend rebuild and fix the valve body which cost me around $750 now the car runs perfect better then it has ever run, very smooth!
user 739030
Sep 16, 2015 06:03 PM
Andrew Namel
Sep 12, 2015 08:49 AM
potterstein
Sep 11, 2015 09:24 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Eurothrasher
Sep 9, 2015 12:00 PM
