Interior/Exterior Here are my New Greddy Gauges & Alta Gauge Pod
Old Mar 10, 2004 | 03:55 PM
Kotchie's Avatar
Kotchie
I recently installed a set of Greddy Gauges in an Alta Gauge pod.
Very happy with the result.
The Greddy Silver 60 MM series are a perfect match for the factory instruments, down to orange backlighting, orange pointers, and the point hub even matches (sort of)
These instruments are expensive (esp. in Canada) but look beautiful. They include full installation parts (except oil temp sensor adapter), have memories & alert settings, and dim with the factory dash lights.
See this link:
http://www.greddy.com/products/produ...rning%20Gauges
Cheers,
David
Old Mar 10, 2004 | 07:21 PM
ColoradoMark's Avatar
ColoradoMark
Good job. Boost and oil temp?
Full sized pic
_________________
IB/W some mods
Old Mar 10, 2004 | 07:40 PM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
Nice install! :smile: I'm using Auto Meter mechanical gauges with Auto Meter pods, costed around $120 US.
I noticed that the pressure gauge reads "TURBO." I assume its function is essentially the same as supercharged application. The meter scale is in metric (kg/cm), unlike Psi that's more common in the US. I guess metric system is a Canadian thing, eh!
Old Mar 11, 2004 | 06:03 AM
KevinR's Avatar
KevinR
Looks nice, but why does it say "Turbo" on the face?
Old Mar 11, 2004 | 06:05 AM
Redline0026's Avatar
Redline0026
Sweetness!!! I'm a huge Greddy fan. I had some greddy gauges in my turbo integra. I'm planning on putting some A'PEXi gauges in my mini or Blitz. Yours are very nice.
Good job,
Old Mar 11, 2004 | 09:54 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Awesome gauges, and nice, clean installation!
Old Mar 11, 2004 | 09:56 AM
ZAMIRZ's Avatar
ZAMIRZ
All GReddy boost gauges say "Turbo".
Old Mar 11, 2004 | 05:09 PM
Kotchie's Avatar
Kotchie
>> As someone else mentioned, the Greddy Line of boost gauges all say Turbo - really my only issue with this setup.
The callibrations work out at 1.0 Kg/cm2 = 14.22 PSI. I have only seen 0.8 kg/cm2 so far at FOT. This translates to about 11.4 PSI - That sounds a bit low, I thought the MCS peaked at 14.0 PSI. Anyone know?
Yep, these gauges are from the US, but as afaik, they are only available in Metric callibrations. Can you say Canadian Eh??
Thanks for the nice feedback, and if anyone wants installation instructions, post here & I'll respond.
Cheers,
David
Old Mar 11, 2004 | 05:12 PM
Kotchie's Avatar
Kotchie
>>Full sized pic
>>_________________
>>IB/W some mods
Cheers,
David
Kotchie's Avatar
Kotchie
>>Full sized pic
>>_________________
>>IB/W some mods
Cheers,
David
Old Mar 11, 2004 | 08:40 PM
ColoradoMark
to get the full size you need to take the work thumb out of the URL address for the pic.
PsychoRallye
21
Feb 17, 2019 06:08 AM
JamesDeBart
Apr 16, 2016 05:00 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
jennster
Sep 28, 2015 06:19 PM
gnhovis
Sep 28, 2015 06:28 AM
