automatic kickdown problem
Old May 16, 2012 | 06:01 PM
rapier2002's Avatar
rapier2002
Hi all, just joined today. I have a 2009 Mini Cooper-S automatic and the gas pedal doesn't push past the kickdown point. This recently happened along with my low tire light coming on (the low tire light isn't an issue but it has been a recurring problem as one of my tires steadily loses psi.) I wonder what may be the cause and what I can do to fix it outside of taking it to the dealership. Thanks!
Old Jun 8, 2012 | 03:59 AM
jurni's Avatar
jurni
I think you might get a better response if you post this in the Hardtop forum. I wish you the best of luck with your problem!
Old Jun 8, 2012 | 08:45 AM
MINIdave's Avatar
MINIdave
Is this somehow different than the way it used to feel?
Since these cars are drive by wire, if there is a problem it's probably in the throttle position sensor connected to the pedal, you might make sure you don't have a floor mat or something getting in the way of the pedal travel, other than that it pretty much has to be in the sensor if the pedal isn't moving the way it used to.
lalroma
20
Apr 2, 2022 06:19 PM
chandler_vt
Apr 29, 2017 08:08 AM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
ki7hy
Aug 12, 2015 07:07 PM
