Alternator replaced/Power steering problem
Old May 14, 2012 | 05:50 PM
azkid's Avatar
azkid
I recently replaced my alternator on mini 2004 mini cooper non S with a lot of help from this forum, much thanks! I have stange problem with the power steering after replacing the alternator. Intermittently the power steering takes a second or two to kick in after starting. The only thing I can figure is the non oem alternator I installed a Bosch is somehow different. I noticed when I first checked the new alternator after install that it took a second or two to show charging on my meter. Could this be my problem or just a coincidence? On a side note fully charged battery and had the battery load tested, which came out good before first start with the new alternator.
Old May 14, 2012 | 07:04 PM
ZippyNH's Avatar
ZippyNH
The ps pump has a "SENSE" Wire...so it will only run when the alternator is making voltage....so it sounds like you found the issue...a alternator that is for somereason delaying output....
Old May 14, 2012 | 07:54 PM
azkid's Avatar
azkid
Thanks ZippyNH, guess I'll live with it then.
Old Aug 31, 2019 | 12:57 AM
Sam Scuderi's Avatar
Sam Scuderi
I have the exact same problem
after I had the alternator changed there is the occasional delay in the power steering
hope this doesn’t lead to another problem
JAB 67
Apr 21, 2018 02:16 PM
SniperDetailing
Dec 22, 2017 01:33 PM
laflamme
Nov 1, 2014 08:48 AM
JKG8R
Electrical
Apr 2, 2012 05:27 AM
tyroneco
Mar 28, 2009 06:39 PM
