Drivetrain Changing Clubbie from auto to stick?
A.) Feasible, sure... realistic? Ehh, not so much.
B.) it will nickel and dime you to death as you will need, the transmission, the mounts, clutch, clutch pedal and manual pedal box, shifter assembly, cables, all necessary hardware and even CANBUS programming since the ECU won't be communicating with the TCU. It's a fiasco and requires alot of tear down to convert and swap over.
- Erik
- Erik
I don't think anyone has ever done it either (i could be wroung)
ki7hy
Aug 12, 2015 07:07 PM
