Drivetrain Changing Clubbie from auto to stick?
Old May 1, 2012 | 08:35 PM
Gerarddm's Avatar
Gerarddm
Any idea if changing a Clubman from automatic transmission to manual transmission is:
a) feasible
b) costly?
Old May 1, 2012 | 11:24 PM
bluefox280's Avatar
bluefox280
A.) Feasible, sure... realistic? Ehh, not so much.
B.) it will nickel and dime you to death as you will need, the transmission, the mounts, clutch, clutch pedal and manual pedal box, shifter assembly, cables, all necessary hardware and even CANBUS programming since the ECU won't be communicating with the TCU. It's a fiasco and requires alot of tear down to convert and swap over.
- Erik
Old May 2, 2012 | 04:15 PM
aklucsarits's Avatar
aklucsarits
It would be cheaper to sell your current car and buy a similar one with the manual transmission that you want.
Old May 2, 2012 | 05:15 PM
ACEkraut11's Avatar
ACEkraut11
+1 And a lot less headaches.
Old May 3, 2012 | 01:26 PM
Ginvent's Avatar
Ginvent
hell of allot cheaper.
I don't think anyone has ever done it either (i could be wroung)
Old May 3, 2012 | 03:53 PM
pdubb's Avatar
pdubb
Not to mention the resale value would go through the toilet if you did that. You might also have to completely replace the ECU.
Colt45Magnus
Jul 14, 2019 06:18 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
ki7hy
Aug 12, 2015 07:07 PM
