R56 Radiator fan always stays on after having water pump recall performed
Old May 1, 2012 | 01:46 PM
Mindspin311's Avatar
Mindspin311
So I have noticed that ever since having the water pump recall performed, the radiator fan is always remaining on after I shut down the car after a drive.
Now, I know that this is a design feature to aide in cooling once the car is off. In the past, I have only noticed it staying on maybe 10% of the time. Now, after the recall work, it seems that it remains on 90% of the time.
Was there also am associated software update that makes the fan stay on longer after the car has been shut down?
Old May 1, 2012 | 06:02 PM
05r50's Avatar
05r50
Just asking, but is it the new cooling pump motor and not the fan you are hearing?
I noticed that my replacement pump is a bit noisier than the original.
Old May 2, 2012 | 05:55 AM
Mindspin311
It sure sounds like a fan! But I can double check. Ive noticed it running at various speeds.
Old May 4, 2012 | 06:35 AM
Mindspin311
Yea, its definitely the fan. Like no doubt. Sucker is always on.
Old May 8, 2012 | 11:07 AM
Mindspin311
Yea I dont know whats going on. Even in the morning when I drive 20 mins to work and its 65-70, the fan will be on, almost full blast, when I shut the car down.
Old May 8, 2012 | 11:22 AM
2009R56JCW's Avatar
2009R56JCW
Nothing to worry about it is sop for the fan.
Old May 8, 2012 | 11:28 AM
Porthos's Avatar
Porthos
Mine does the same thing. I think it is part of the cooling system. Some programing to keep the car from bursting into flames.
Old May 8, 2012 | 12:08 PM
Mindspin311
Well I understand that. Just seems to be overly active. I bought the car last august when temps were much higher and I never remember the fan being on this often.
I only really noticed things after the recall was performed. Maybe they didnt get a good fill on the coolant and there are some air pockets mucking things up.
Old May 8, 2012 | 12:44 PM
Porthos's Avatar
Porthos
Ask the dealership. I would not be to concerned with it. Its not like you have to sit there and wait for it to turn off.
Old May 8, 2012 | 12:52 PM
drsimmons's Avatar
drsimmons
My 07 does the same thing but it really depends on the temp outside and how far I drive it.
It only stays on for about 45 seconds at most.
I don't hear any difference in the new aux pump as far as noise, it seems
fairly quiet IMO.
Might be the Forge FMIC I installed at the same time I had the aux pump changed out.
Don't they both cool the turbo down.
Old May 8, 2012 | 02:36 PM
Mindspin311
Oh mine will go minutes. I stopped into Harbor Freight this weekend. Was in there maybe 5-7 minutes. Came out and the fan was still on. Temp was probably low-mid 80s.
Old May 8, 2012 | 02:52 PM
drsimmons's Avatar
drsimmons
That does seem a little too long. Have you checked your coolant bottle?
Is is up to the full line?
Old May 8, 2012 | 02:57 PM
Mindspin311
Last I saw, it was in between the min and max lines. I am going to try and "burp" it this weekend via that bleeder screw. Will pick up some super special coolant to see if that will help. BMW and Mini are the same stuff, right? The BMW dealer is on the way home, unlike the Mini dealer which now has its own building on the other side of town.
Old May 8, 2012 | 03:19 PM
drsimmons's Avatar
drsimmons
Bleeding the line was my next thing and YES, the BMW and Mini coolant are the same thing.
Way back I had a leak in my thermostat but couldn't see any fluid leaking anywhere. Ended up blowing out the bottom while moving but every couple of days my coolant bottle would be darn near empty.
Let us know if that helps.
Old May 8, 2012 | 04:02 PM
Porthos's Avatar
Porthos
fairly quiet IMO.
Intercooler does not cool the turbo down but cools down the intake charge.
Old May 8, 2012 | 04:11 PM
drsimmons's Avatar
drsimmons
^^Thanks, wasn't too sure about that one. It looks cool though. LOL
Old May 8, 2012 | 04:40 PM
Porthos's Avatar
Porthos
Looks cool and works that is all that matters.
Old May 12, 2012 | 02:47 PM
Mindspin311
So, overflow is at max level. Opened the vent screw and turned on the car. Idled for like 10 mins, radiator fan finally kicked on.
I never saw a thing come out of the vent. I opened it 2 complete turns. Nothing.
Old May 12, 2012 | 04:32 PM
drsimmons's Avatar
drsimmons
When I did mine this is what I did.
1. Start engine
2. Turn heat to high and speed to high
3. Loosen bleeder valve until you hear air release.
4. When no more air is heard, close bleeder valve.
5. Top off coolant bottle.
6. Repeat until coolant comes out of bleeder valve.
7. Recheck coolant level and you should be done.
Old May 12, 2012 | 05:48 PM
Mindspin311
Level in the overflow hasnt changed, at all.
Is it possible the thermostat has failed and it wont open up.
Old May 12, 2012 | 05:59 PM
drsimmons's Avatar
drsimmons
If you are for sure you bled it thorougly and you have heat coming out of the vents, I doubt the thermostat is stuck.
Give it a day or so and keep an eye on the coolant level. Even mine seems to sporatically come on sooner than other times. Seems more so since I've had my thermostat replaced. Even at that it still only seems to run about 45 sec to 1 min. I don't know what is normal on the run time.
I just bought and installed one of those ScanGauge II's. Kinda up in price, $170 w/tax but now I can monitor stuff like water temp., intake temp, etc. I noticed my water temp (at operating temp) is about 220-225. That is normal so I'm happy.
Just wish the gauge would display oil pressure.
Keep us in touch on outcome.
Old May 12, 2012 | 06:34 PM
Mindspin311
Well, I was just able to access the coolant temp through the super secret menu found here:
https://www.northamericanmotoring.co...316-post6.html
I saw anywhere between 223F and 239F. Which seems within the normal range. I guess I have an overactive fan? I feel like it was never this active when I 1st bought the car last July.
Old May 12, 2012 | 08:21 PM
drsimmons's Avatar
drsimmons
Tha's funny because when I bought mine Aug last year same thing. Fan did't come on for quite awhile then all the sudden it started to come on. Soon after I bought it I had the thermostat replaced so I'm guessing that's why mine started working more frequently.
Didn't know about the secret dealy, I'll have to try that out as well.
Old May 12, 2012 | 10:44 PM
Ch28Kid's Avatar
Ch28Kid
I never hear my radiator fan turn on at all.
I drive for 15 minutes and it basically stay at 103 - 106 C (217.4 - 225) until I turn my car off. I never it it drop below 100. Since my car is out of warranty, there is no way for me to test if my radiator fan is working properly. I'm using Scanguage II to read all my temp.
@Mindspin311
Add 2 extra steps. This is what the MINI Tech told me when I bought my coolant.
1. Start engine
3. Loosen bleeder valve until you hear air release and open coolant tank.
4. Go to bottom front of the bumper and located the radiator tube.
5. Squeeze the tube at the radiator and pour again until there is no more bubbles.
6. When no more air is heard, close bleeder valve.
7. Top off coolant bottle.
8. Repeat until coolant comes out of bleeder valve.
9. Recheck coolant level and you should be done.
Old May 13, 2012 | 07:03 AM
Mindspin311
How many "turns" does it take to open the bleeder? I gave it 2 complete revolutions and nothing came out. Nor did I hear any air escaping.
