Suspension Slotting the front strut top mounting holes: how much negati
Old Mar 7, 2004 | 07:50 PM
2Cool's Avatar
2Cool
I am still having a hard time paying 2-1/2 to 3 times what I pay for domestic car camber plates just because our cars have BMW in their family tree somewhere. So, if anyone has slotted the three bolt holes in the strut tower, how much negative camber can you pick up? I can see that there is a definite limit to the amount you can slot, as the inside hole is roughly 1/2" from the side of the strut tower. But that 1/2" should translate to noticeable negative camber change. This mod is allowed in STX, so I am very curious what the total amount I can expect would be... anyone?
Old Mar 7, 2004 | 08:11 PM
JustGo4It_'s Avatar
JustGo4It_
If I remeber correctly 1/4 inch of movement should net you around 1 degree of change. The question is how much can you move the upper strut bearing over before it bangs on the strut tower?
Old Mar 7, 2004 | 11:27 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I wonder if slotting would cause any weakening of the strut tower.
Also are the bolts long enough to move their position and still have enough thread to tighten the nut securely?
If you don't hear from anyone try calling Randy Webb- maybe he has seen someone try this.
What happens if you cut the slot wrong??
Old Mar 8, 2004 | 07:41 AM
jlm's Avatar
jlm
Slotting should work. The limiting factor, as far as range of movement, is the coil spring/spring retainer contacting the inner wall of the strut tower. There is about 1/2" to 5/8" inward travel available which gives about 2 to 2.5 total negative camber. Most are reluctant to start cutting up the body, hence the adjustable plates. I would add 5/16 id fender washers (larger od) under the flange nuts
Old Mar 8, 2004 | 08:21 AM
conecarver's Avatar
conecarver
You may want to double check the stx rules on this... I know bolt in camber plates are legal but I am doubtfull that slotting the factory holes is.... Def. double check the 04 rulebook!!!
Old Mar 8, 2004 | 09:24 AM
2Cool's Avatar
2Cool
The rules state that slotting is allowed: http://www.moutons.org/sccasolo/Rule...t_touring.html
17.8 C. On vehicles with strut-type suspensions, adjustable camber plates may be installed at the top of the strut, and the original upper mounting holes may be slotted. The drilling of holes in order to perform the installation is permitted. The center clearance hole may not be modified. Any type of bearing or bushing may be used in the adjustable camber plate attachment to the strut. The installation may incorporate an alternate upper spring perch/seat and/or mounting block (bearing mount). Any ride height change resulting from installation of camber plates is allowed. Caster changes resulting from the use of camber places are permitted.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
FLYM1N1
Aug 15, 2015 11:20 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
bleonard1401
Aug 4, 2015 09:39 PM
