oil leak
Old Apr 18, 2012 | 05:02 AM
GregO's Avatar
GregO
oil leak
Hi Folks,
I will putting our '06 S into the shop for what I expect to be a crank sensor O-ring replacement. Should that be the case, are there other recommended items I should ask the shop to check or replace while having the front off?
Car has 45,000 miles on it and has had no major repairs or services, only maintenance such as fluid flushes, etc.
Thanks!
Greg
Old Apr 18, 2012 | 08:01 AM
quikmni's Avatar
quikmni
I just replaced the crank sensor o-ring. I can not think of anything else in the front to replace. They should check the hoses but I would not expect any issues.
When I did the crank o-ring I also replaced the crank damper but I have 75,000 miles.
There are other normal things to check at 45,000 miles such as lower front control arm bushings, belt tensioner, and belt.
Also check the engine mount for leaks.
Old Apr 19, 2012 | 09:31 AM
GregO's Avatar
GregO
oil leak
Thanks!
Greg
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
