Drivetrain upgrade coil , plugs , wires.....?
Old Apr 12, 2012 | 05:10 AM
inkspot1967's Avatar
inkspot1967
I want to upgrade my stock coil , wires and plugs on my 2008 MCs cabrio.
What is the best option for these?
No pulley install as of yet and not sure when and if im gonna do one.
Thx mike
Old Apr 12, 2012 | 06:14 AM
BlwnAway's Avatar
BlwnAway
Coil: Don't bother the factory coil works as good or better than the aftermarkets & will generally last longer also. (190,000 miles on mine)
Wires: Again not much difference, just don't buy cheap ones. (I switch from my good wires to my OEM's all the time doing diagnosis of electrical issues, miss-fires & such, don't really notice a difference)
Plugs: Still stock, No pulley=NGK BKR6EIX
pulley=NGK BKR7EIX
Old Apr 12, 2012 | 06:34 AM
inkspot1967
Thx i am getting a #2 cylinder misfire now. The cel comes on and goes off every so often and i get the p302 code.
I know this may not fix it but i thought it couldnt hurt either. I have to order the spark plug tool so i can pull it out and see whats up, and maybe get a compression gauge not sure if all gauges are the same or i need a special one for the mini.
The car runs fine after the light goes out so im not sure whats wrong.
Old Apr 12, 2012 | 06:50 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
You don't say how many miles on the coil, plugs and wires. First thing I'd do is pull the boots off the coil and clean the corrosion off the coil terminals and inside the corresponding ignition wire terminals. See if that helps the situation before throwing $ at the problem.
Old Apr 12, 2012 | 06:56 AM
inkspot1967
Opps.....it has 28,600 miles on it.
Old Apr 12, 2012 | 07:14 AM
ZippyNH's Avatar
ZippyNH
Other than checking for corrosion on the coil pack plug, with that few miles, no pulley, the plugs and wires are almost new...by miles anyway...
Plugs, coil and wires imo are likely a waste of $$ with so few miles unless they are faulty...just tossing parts at a problem hopeing it may fix it is not usually a cost effective way to deal with a problem...
If you do pull the plugs, do use a tourqe wrench to reinstall them.....
The compression check will give you a better idea whats going on....IF you lnow how to do it and interpert the results...sounds of where the air is leaking from, wet/dry....might be worth paying a couple $$ to get it done and a pro's opinion.
Old Apr 12, 2012 | 07:34 AM
inkspot1967
Thx i do plan on checking it before i just wanted to get a idea if it was even worth doing as just a upgrade not so much as fixing the cel. But from what i read there is no need to do the upgrade parts since its the same as stock.
I will switch plug wires one and two around see if its the wires first, then pull the plug once i get the socket for it.
Thx guys.
Old Apr 12, 2012 | 08:51 AM
BlwnAway's Avatar
BlwnAway
Yes you should inspect & clean terminals on the coil, and of course make sure the wire boots are seated properly.
But before you swap plug wires around, pull the plugs first to see if there's a visable difference, and when you do make sure that #2 was tight (could possible be the problem also)
Special tool? Small sparkplug socket w/ the rubber insert removed or 5/8 deep well socket
and
One of these:
Use the telescoping claw to also re-insert the plugs & get them started.
Torque to 22 ft/lb (TORQUEING PLUGS IS A MUST)
After doing both of these things, clear the code & drive the car & see what happens.
Still the same problem on the same cylinder, then do the wire swap, don't forget, diagnose one step at a time.
Old Apr 12, 2012 | 09:00 AM
inkspot1967
Ok thx i will do that first and see how it goes. Gotta love this website lots of great people here and very helpful.
Old Apr 12, 2012 | 09:30 AM
BlwnAway's Avatar
BlwnAway
BTW, Walmart had some of those telescoping claws w/ a light on the tip, I've actually found it to be pretty handy.
Old Apr 12, 2012 | 09:54 AM
NC TRACKRAT
Veteran: Navy
Suggestion: Before pulling the plugs, I use an air compressor and a fine nozzle to blow out any debris in the spark plug well. You don't want anything dropping down in there! I know this is like discussing brands of oil but, keep in mind, this is an Aluminum head. I use a smidgen of anti-seize on the threads and only torque to 20 lb.ft. max. Also, I use a 3/8" extension on a magnetic spark plug socket and use a strip of duct tape to make sure they don't separate.
Teh
Aug 22, 2022 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
yashmack
Aug 15, 2015 10:16 AM
sabjcw
Aug 14, 2015 07:40 AM
