Fuel gauge not working correctly after fuel pump change
Old Apr 2, 2012 | 01:41 PM
movieman's Avatar
movieman
So, I had a fuel pump go out on me a couple of weeks ago, the replacement pump was fine, then it died on me the other day. After the car got towed to the shop and they re-replaced the pump with a dealer part, they discovered that it was out of gas. The gas gauge said it had 1/4 tank. They put gas in, and the gauge isn't reading correctly still.
Any suggestions on what this could be?
Old Apr 2, 2012 | 03:09 PM
sbeezy's Avatar
sbeezy
fuel gauge sending unit maybe.
Old Apr 2, 2012 | 04:18 PM
movieman's Avatar
movieman
Isn't the sending unit part of the pump?
Old Apr 7, 2012 | 05:52 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
The sending unit arm hangs on the outer shell of the pump/filter assembly. They may well have dislodged or bent it when they installed the new pump. (See REALOEM parts diagram). Take it back and tell them to fix it.
Old Jul 22, 2012 | 08:33 PM
mernbrad's Avatar
mernbrad
Mine did the same thing and I was told the fuel filter sending unit was bad along with the pump sending unit. The fuel filter is on the right side of the tank. I had to replace both of the parts it took a couple hours. After the replacement the tank was showing 1/4 of fuel. This was my Saturday project I haven't run a full tank of fuel yet. The up side the car runs better at idle and under normal acceleration.
Old Jul 28, 2014 | 12:57 PM
famguy's Avatar
famguy
I have the same issue after installing a new original fuel pump.
I've double checked that the arm isn't bent and is working just fine, but the fuel gauge is not working at all.
What could it be? I guess the fuel gauge itself doesn't have its own fuse?
sprp85
Aug 22, 2015 06:16 AM
skippermini
Aug 13, 2015 06:13 AM
kpl
Aug 11, 2015 04:52 AM
bc219
Aug 10, 2015 11:22 AM
