advice please 17x8
advice please 17x8
hi all im new
had my mini a while now and im looking to get some 17x8 et35 calibre vintage wheels for it. Ill be running 205/40/17 tyres but i also have ap racing BBK am i gonna have issues with fitting these wheels? am i going to need spacers? also car lowered on KW v1 coilovers
appreciate any help!! did use search but couldnt find the correct answer
many thanks
had my mini a while now and im looking to get some 17x8 et35 calibre vintage wheels for it. Ill be running 205/40/17 tyres but i also have ap racing BBK am i gonna have issues with fitting these wheels? am i going to need spacers? also car lowered on KW v1 coiloversappreciate any help!! did use search but couldnt find the correct answer
many thanks
You're kinda in a rock and a hard place; AP Racing specifically denotes that the standard 17in wheels won't fit without a spacer.
However, their also noting that most aftermarket 17in wheel will fit; it's like as double standard.
You need to measure the rotor mounting surface of the wheel to the outside edge of the caliper.
Then you need to get a hold of Calibre Wheels and ask the clearance.
Typically an 8in wide wheel with a 35mm offset will clear most BBK's, but you need to double check before you have a set of wheels may not work.
- Erik
- Erik
bradstyle
Oct 1, 2015 11:15 AM
