Anybody running 215/40/18 with lowered car?
Old Mar 27, 2012 | 09:22 AM
Tata Steva's Avatar
Tata Steva
Just need some feedback on following combo:
Tires: 215/40/18
Wheels: 18x7
Suspension: lowered on (NM) springs or coils...
Any rubbing or issues?
Thanks.
Old Mar 27, 2012 | 11:51 AM
quikmni's Avatar
quikmni
I am running 215/40-18 on 18x7 wheels on my 2006 MCS. My car has the JCW suspension so lowered about 1/2" to 5/8". With the stock 52mm offset wheels, I did not have any rubbing.
I than added 15mm spacers for about 37mm offset (52-15=37). With 37mm offset I had rubbing in the rear outside when the suspension was loaded, such as a bump. Tire would rub slightly on plastic wheel arch and wheel well liner. I trimmed away some of the plastic to eliminate the rub.
Rubbing will depend on the wheel offset and amount lowered.
If you have a R56 I think there is slightly more room in the rear than my R53.
Old Mar 27, 2012 | 12:13 PM
Tata Steva's Avatar
Tata Steva
Thanks!
I am looking for Clubman feedback mostly...
Old Mar 27, 2012 | 02:08 PM
ra2fanatic's Avatar
ra2fanatic
I'm running 215/35/18 on 18x8 square +32. No rubbing; you'll be fine.
edit: woops, didn't see your latest comment. sorry i can't help!
Old Mar 28, 2012 | 02:50 PM
sob4691's Avatar
sob4691
Stupid question but are the 215/40/18 more rubber then a 205/40/18? what area would be bigger or widder?
Old Mar 28, 2012 | 02:57 PM
quikmni's Avatar
quikmni
215 is the width of the tire. 215mm across the tread.
40 is the series of the tire or the ratio of the tire width to sidewall height. Sidewall would be 40% of the width or 215x0.4=86mm.
Thus in general terms a 215 tire is 10mm wider than a 205 tire.
Also a 215/40 (86mm) has a little higher sidewall than a 205/40 (82mm).
The width can vary by manufacuture so a 215 from one manufacture might not be the same as a 215 from another. Check someplace like tirerack.com for actual sizes.
Also the width of the wheel will impact the actual width of the tire when mounted.
Old Mar 31, 2012 | 02:54 AM
howsoonisnow1985's Avatar
howsoonisnow1985
215 is wider than 205.
Old Aug 21, 2012 | 02:59 PM
Tata Steva's Avatar
Tata Steva
still looking for answers...
Old Jan 5, 2013 | 10:22 AM
Day177017's Avatar
Day177017
I just bent and cracked my JCW R113's, so after I get the new wheel in, I'm going to swap. Was actually considering something a bit bigger than 215/40/18 on a 18x7 wheel. Anyone know what's the largest I can go? I want the fatty tire look . My clubman isn't lowered and don't have plans to do so.
Old Jan 7, 2013 | 04:46 PM
Alex@tirerack's Avatar
Alex@tirerack
215/35R18 is the safe way, as we discussed. Thanks for the call!
Old Jan 7, 2013 | 05:47 PM
Tata Steva's Avatar
Tata Steva
Alex,
Can you chime in on my original question (regarding lowered Clubmnan S)?
Old Jan 8, 2013 | 09:18 PM
CHKMINI's Avatar
CHKMINI
No Clubman but I've ran 215 40 18 with NM Lowering Springs on my '09 JCW and now my '12 JCW Coupe without any rubbing issues. The stance with 215 40's looks great! I ran 215 35's and constantly bent wheels because of the rubber band sidewall.
Old Jan 9, 2013 | 05:01 AM
Creeve's Avatar
Creeve
It doesn't matter if is a clubman, R55/56/57/58/59 are all identical where tire fitment is concerned. What is the offset of the wheels?
Old Feb 26, 2013 | 06:48 AM
Tata Steva's Avatar
Tata Steva
New rims on order:
18x8
ET 42
Still looking if I can "tuck" 215/40/18...
Old Mar 10, 2013 | 10:07 AM
RA082324's Avatar
RA082324
has anyone tried fitting a 225/45R17 on a lowered r53?
Old Apr 10, 2013 | 07:47 PM
ryanschram's Avatar
ryanschram
I've been on 215/45/18 Continental DWS for a few weeks now. Main reason was so the speedometer shows the correct speed. 09 JCW Clubby on H&R RSS coil overs. Tucking tire and my front bumper air dam thing sits about a 1/2" off the ground at its lowest point.
So basically, slammed and no issues
Old Jun 22, 2014 | 02:41 PM
bowdown's Avatar
bowdown
similar question with some specifics...... does anyone know the offset of an O.Z. Superleggera? If I was to get an O.Z. Superlegerra that is 18x7 , lower my car with H&R springs, can I go with a 215/40/18 without any fitment or even a tiny bit of rubbing issue on an R53 even with passengers??
Old Jun 23, 2014 | 05:04 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
bowdown, I think you're going to run into trouble trying to get that 17" tire on an 18" rim! In all probability, you meant 215/40x18, right?
Old Jun 23, 2014 | 08:34 AM
bowdown's Avatar
bowdown
oops .. yeah thats what I meant 215/40/18
Old Mar 26, 2015 | 11:18 AM
djmatthewcooper's Avatar
djmatthewcooper
bowdown, have you gotten any answers in regards to your question. I have 18x7 OZ Superleggera's and just ordered 215/40/18. I am thinking of returning and switching to 205 as I don't want that fat tire look.
jeremy_reyes94
Sep 6, 2019 07:53 AM
Minibeagle
Aug 13, 2015 10:00 AM
Lt. Dan
Aug 10, 2015 12:46 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
