Noise after shutting off engine
Old Mar 23, 2012 | 06:58 PM
NNJMCS's Avatar
NNJMCS
I'm getting a strange noise, appears to be under the turbo. It sounds like something is shorting out with a hum after the car is shut down. Turbo timer short? Dont know. Anyone else?
Old Mar 23, 2012 | 07:39 PM
52804x4's Avatar
52804x4
I believe it is just the fan cooling the turbo. I always have a low hum after I shut the car down. It goes away after 10min or so.
Old Mar 23, 2012 | 08:17 PM
Gil-galad's Avatar
Gil-galad
Almost got it right...it's the auxiliary water pump, not a fan. It cools the the turbo in the absence of circulating oil and air after shutting down the engine.
It is indeed a normal and most welcome sound.
Old Mar 23, 2012 | 10:33 PM
52804x4's Avatar
52804x4
Thanks for the clarification! This is my first week with my first MINI. . .I'm learning as I go here!
Old Mar 24, 2012 | 07:55 AM
yetti96's Avatar
yetti96
There is both a fan and the Aux coolant pump. The fan will be obvious and loud, it is to cool the water that the much quieter aux pump is circulating. The fan is not an every time thing but often after hard driving, then parking it will kick on.
Old Jul 17, 2013 | 05:35 AM
EHans's Avatar
EHans
Thanks. Do you have any info on this? Mine did it last night and I knew it wasn't a fan as it was too quiet. I'd like to know more what this is doing. Is it just around the turbo, the whole motor?
But yup, after 10 min, it shut off and there was a quiet but noticeable "click" as if some valve was closing or something.
Old Jul 17, 2013 | 11:05 AM
fkelly5's Avatar
fkelly5
same same happens with my '13 CMS. Runs longer if I ran the car hard. Most of the time never really noticeable.
Old Jul 17, 2013 | 08:05 PM
shark715's Avatar
shark715
Yes, both our 2012 and 2013 CMSA4 (As well as or 2011 BMW X5) make that same soft humming noise after engine shutdown. It is the auxiliary coolant pump running coolant through the turbo(s) to cool it down. And the hotter the weather and the harder you have driven the car right before engine shutdown, the longer you will hear the pump run.
woodstudio
Mar 15, 2020 08:28 AM
cerenkov
Apr 24, 2018 07:47 AM
R60abq
Jun 6, 2017 05:15 PM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
