The Dreaded Fuel Question
Old Mar 21, 2012 | 03:32 PM
ewanders1's Avatar
ewanders1
Has anyone ran less that Premium fuel ? I see the manual says that you can run 89 that seem to be the mid grade ?
Old Mar 21, 2012 | 07:23 PM
yoggie's Avatar
yoggie
I have run lower grade gas without any issues. However, studies have been done on other turbo 4s (non-MINIs) and found that premium fuel is cheaper per mile than mid grade gas. From what I understand, to run the lower grade gas the engine has to retard and timing so it is decreasing its power and mpg in the process. So in the end, the car will run on 89 but 91 will probably give you more power, higher mpg, and lower cost per mile.
Old Mar 21, 2012 | 09:24 PM
WMW's Avatar
WMW
Mileage
I get the same mpg whether I buy 89 or 91. Most of the time it is 89 for me...
Old Mar 21, 2012 | 10:09 PM
Fly'n Brick's Avatar
Fly'n Brick
This question has been asked many times on this forum and the answer is still the same. High performance engines require high performance fuel. Simple as that. Trying to be economical by running cheaper fuel is penny wise and pound foolish every day of the week.
http://www.toptiergas.com/index.html
http://pure-gas.org/index.jsp?
Old Mar 22, 2012 | 06:52 AM
WMW's Avatar
WMW
Fuel
Running 89 is approved...so no problem running. If 91 is what you like go for it.
Old Mar 22, 2012 | 07:28 AM
Machz's Avatar
Machz
89 will run just fine, I wouldn't call a 181 Hp 1.6 exactly high performance.If MINI says it's ok then you can bet it is as MFG usually are on the cautious side. Maybe if it's 90+ and you are running the hills but day to day it's fine.
But you can also look at it as the price diff is normally about 10 cents per gallon so you are saving a whopping $1.20 +-
Old Mar 22, 2012 | 07:46 AM
Fly'n Brick
The term high performance is derived from the fact that the little 4 cylinder engine under the bonnet is designed by virtue of head clearance, stroke, valve clearance and a couple of other cute ideas to provide more horsepower than it could normally provide. The compression ratio is decidedly different than your average commuter box. So yes, it is. If it weren't, what would be attraction to MINI and the proliferation of aftermarket competition equipment?
Old Mar 22, 2012 | 07:54 AM
ZippyNH's Avatar
ZippyNH
Just use What THE MANUAL FOR YOUR TYPE OF MINI CALLS FOR....
for a gen1 prem is needed, but this is a gen2 countryman thread...diff motor.
Old Mar 22, 2012 | 10:34 AM
menehune2011's Avatar
menehune2011
Hey Zippy.... can you clarify generation 1 vs generation 2? Is a 2011 (1) and 2012 (2)? So if I own a 2011 I should use premium gas?
Machz's Avatar
Machz
I guess we will have to agree to disagree. Fords 1.6 turbo makes 178 HP I wouldn't call that high performance. They make aftermarket parts for the early 100+HP civics so that doesn't make it high performance either. To be honest when I floor my mini the last thing I think is high performance but that's me.
Old Mar 22, 2012 | 11:47 AM
countryman-s's Avatar
countryman-s
i would think any motor that was able to make 100hp per liter would be high performance. so a mustang 5.0 liter should make 500hp right?
Old Mar 22, 2012 | 12:02 PM
jcauseyfd's Avatar
jcauseyfd
2011 is 2nd gen.
Old Mar 22, 2012 | 12:10 PM
menehune2011
Originally Posted by jcauseyfd
2011 is 2nd gen.
So what's considered 1st Generation?
Old Mar 22, 2012 | 01:42 PM
Machz's Avatar
Machz
No more like 700+with boost As the mini without boost makes 120
Like I said I personally don,t consider this anywhere near high performance I guess some others do. But in the end this was about octane and Even though I choose to run93 if mini says 89 is ok that tells me that it is.
Old Mar 22, 2012 | 02:29 PM
jcauseyfd's Avatar
jcauseyfd
For most models, 2002 - 2006. iirc, verts didn't switch until 2009.
Old Mar 23, 2012 | 09:01 PM
Bakerbrdz's Avatar
Bakerbrdz
I use bananas and miller beer in my mr diffusion. I only need to get up to 88 miles per hour
Old Mar 23, 2012 | 09:41 PM
b&WCM's Avatar
b&WCM
You would be wrong! It is not an agree to disagree proposition.
The Prince 1.6L is definitely a high performance engine. The Compression ratio is in excess of 11:1, it is direct fuel injected and has a very high HP to weight ratio.
High performance is not about speed, it is about getting the most power from what displacement you have.
Yes, Ford's new ecoboost engine is also high performance although the compression ratio in the 10:1 range.
Most engines have compression ratios of 8 or 9 to 1. Anything in the 11 or above range will most likely need high octane fuel to prevent early detonation.
Porsche's state-of-the-art new Boxster engine has a 12.5:1 compression ratio
for comparison.
Old Mar 24, 2012 | 03:35 AM
Machz's Avatar
Machz
for comparison.
Like I said I don't agree, compression isn't the only determination of high performance. Ecoboost high performance? That must be why they call it ECO boost.
There are 4 cyl motors out there that I would consider hp just not this one. 120 hp without boost is a joke and 181 with isn't impressive to me either. But like I said this was about octane and I would rather listen to the people that built the car instead of some guy on the Internet that thinks he knows what he is talking about.
Old Mar 24, 2012 | 06:53 AM
ZippyNH's Avatar
ZippyNH
2002-2006 hardtop, non s and s (r-50+r53), and 2005-2008 cabrio, s and non s(r52).
These gen1 cars all had the Tri-tech motor...
The Prince motor was introduced on the new chasis...hence the seperation in gen1 to gen2.
I pointed that out because some folks think of all mini's as just mini's...but due to the motor changes, there are differances....
Heck even among the prince engine gen2 cars, there are some pretty major differences...look at rhe specs for cars with vvt as compared to without in gen2. I just saw a fellow gen1 owner trying to tell a gen2 owner about their car, and figured i habetter point out this was a gen AND model specfic thread...not a general thread...
The important thing is to use the octane reccomed in YOUR manual...never less..
More, in some cases allows the computer to add timing to make more hp, but less can cause detonation, ping and other major engine dammage.
Old Mar 24, 2012 | 07:21 AM
ZippyNH's Avatar
ZippyNH
It also dependd on where you live...in the northeast, we have 93 or 94, with 90 being mid...
in the west or ca, 90 or 91 can be the top grade.....so hence a bit of the confusion...
Old Mar 24, 2012 | 07:59 AM
MY4thMINI's Avatar
MY4thMINI
For me personally,
I have used both and I do get a Few more miles out of the higher grade gas.
And in actuality, On a fill up, It's about $2.20 more
Old Mar 26, 2012 | 10:51 AM
worrynot's Avatar
worrynot
A Service adviser mentioned to me they have fuel testing equipment at all BMW service centers for this reason.
PhoR53
May 2, 2026 12:59 PM
David.R53
Sep 1, 2015 06:49 PM
vanhick
Aug 19, 2015 09:03 AM
Getrieben
Aug 15, 2015 09:09 PM
CARdiac
Aug 8, 2015 03:30 PM
