Joining the failed motor mount club...
Old Mar 17, 2012 | 02:25 PM
GoThingNC's Avatar
GoThingNC
While checking the oil last night I noticed the black ooze of death creeping from the top and bottom of the P/S upper motor mount.
MINI just reached 75K
Just placed an order for a new one.
Old Mar 17, 2012 | 03:29 PM
MY4thMINI's Avatar
MY4thMINI
Me 2
Had my 06 in for service about 2 years ago at 53,799 miles they noticed i had issues and replaced the mounts then,
Lucky for me they covered it as a good will gesture.
Old Mar 17, 2012 | 07:09 PM
56 Blue's Avatar
56 Blue
I replaced mine today.
2006 MCS 28,000 miles
Old Mar 17, 2012 | 07:18 PM
MiniRy's Avatar
MiniRy
OK... I worried... I just recently bought a used MCS 08, what's the deal with the motor mounts?
Old Mar 17, 2012 | 07:39 PM
56 Blue's Avatar
56 Blue
Not sure about 2nd generation Minis, but 2006 and earlier cars seem to start leaking with age or miles. Not a big repair. 15 minutes and $100 part.
Old Mar 19, 2012 | 02:29 AM
insanitize's Avatar
insanitize
From: Queens, NY, spend a lot of time in Central NY
I had mine changed last month just before the warantee expired. I have a 2008 MCSc with 23000 miles.
Old Mar 19, 2012 | 09:00 AM
Noir2005's Avatar
Noir2005
Stay tuned guys, in the coming months, I'll be making a write up with photos/video of how to make a permenant fix to our motor mounts.
Old Mar 19, 2012 | 09:45 AM
GoThingNC's Avatar
GoThingNC
I orderd mine for $77 with free shipping
How were you able to swap it out in 15 minutes?
Shortcuts or pratice?
Old Mar 19, 2012 | 02:42 PM
Eric_Rowland's Avatar
Eric_Rowland
Details?
Old Mar 19, 2012 | 06:01 PM
GoThingNC's Avatar
GoThingNC
Pelican Parts
Old Mar 19, 2012 | 07:12 PM
Eric_Rowland
Pelican Parts
Thx.
Old Mar 19, 2012 | 07:32 PM
56 Blue's Avatar
56 Blue
I ordered mine for $77 with free shipping
Shortcuts or practice?
Exaggeration.
Actually it was about 3 hours including detailing frame, sitting on lawn chair and having a beer.
I removed the LF wheel. With floor jack - about 5 minutes
Then the wheel well liner. This might be un-necessary if you put the car on ramps and use long extension with E12 Torx socket to remove bottom bolt. I wanted to clean everything anyway. 3 fasteners are Phillips head screws. The remaining 7 (?) are push rivets that can be removed with Philip's screw driver. I also used a flat blade to keep the rivet base from spinning. another 10 minutes
Then I put a 2nd floor jack and block of wood under the oil pan to take weight off mount. 5 minutes
16 mm box wrench to remove horizontal bolt.
E12 Torx to remove bottom bolt.
13 mm to remove ground strap bolt
17 mm to remove 4 bolts on aluminum frame between top of mount and engine.
I could probably do it all over in about 30 minutes to an hour.... depending on beer. IPA, Bock or Lager
Mount was $98 + $10 shipping. Mount is genuine Mini part, not "or equivalent".
Old Mar 20, 2012 | 05:24 AM
GoThingNC's Avatar
GoThingNC
Thanks for the write up
Might take a few hours for me since I will probably end up detailing the wheel well and suspension parts and inspecting everthing else while I have access.
DixonL2
Apr 13, 2021 08:05 AM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
minipopkart
Aug 13, 2015 05:22 AM
Llanrhaeadr_Cymru
Country Roads MINIs
Aug 5, 2015 02:58 PM
