R58 Water from hatch?
Old Mar 16, 2012 | 05:47 PM
R58's Avatar
R58
Water from hatch?
New guy here, so please be kind if this has already been discussed and I find find in my search. However it rained here last night, and this morning I opened the hatch on my coupe and water poured all in the trunk....
Has anyone else run into this problem? Where is all the water coming from? My guess is the wing area.
I didn't drive my coupe today, so maybe it works it's way out when driving?
Old Mar 18, 2012 | 11:31 AM
artguy's Avatar
artguy
It's just one of those "mini" things. Mine dribbles and pours into the back hatch right where the rear hatch lid sits. Water gets down below it and you have to mop it up.
Old Mar 18, 2012 | 05:58 PM
Keysersozeh's Avatar
Keysersozeh
So I opened my hatch yesterday after a good rain and noticed kinda what you mentioned... There are little thin openings on the side of the trunk that lets the water that collects around the spoiler drain from down the channels around the trunk area. I am guessing if you open too quickly it might splash in or just run in.. Next time it rains, I'll open slowly and see what the experience is.
Old Mar 18, 2012 | 06:45 PM
pdxmini's Avatar
pdxmini
Wet lid pours in when lifted
Ours does the same thing. There are big channels to the sides that catch most of it, but there's definitely some splashing over onto the deck cover and into the boot if I lift the hatch normally... slower means less water all at once and less splashing, but I rarely remember (it's usually raining at the time and I'm not interested in lingering outside the car ).
Old Mar 30, 2012 | 08:21 AM
shmini's Avatar
shmini
Water from hatch in trunk?
Only four posts on this thread...
Does EVERYONE have this problem? Or just isolated incidents of it happening?
Old Mar 30, 2012 | 08:37 AM
Xeraux's Avatar
Xeraux
I opened mine after giving it a wash in order to wipe down the edges of the hatch and the channels and yes, I had some water dribble in. Didn't seem like much of an issue at the time. :dunno
Old Mar 30, 2012 | 09:46 AM
jamesday24's Avatar
jamesday24
I park facing a bit downhill in my driveway and when it rains a lot of water collects in the side channels. I worry it might leak into the boot area, but nothing so far.
Old Mar 30, 2012 | 03:20 PM
minirab's Avatar
minirab
Every wash it does dribble down but then again so did my R53. It's all
part of keeping it clean and dry.
Old Mar 31, 2012 | 08:21 PM
Fastblue's Avatar
Fastblue
I figure it must be best to clean the channels before the rest of the car and use the door in the front of the cargo area when possible if it is raining.
Old Apr 1, 2012 | 08:10 AM
rosvick's Avatar
rosvick
It happened to me the other day too, but it's only because I opened the rear hatch very quickly. The next time it rains, I'll try opening it slowly.
Old Apr 1, 2012 | 07:53 PM
indymidnight's Avatar
indymidnight
Happens to me frequently after rain or car washes...
Old Sep 24, 2012 | 09:10 PM
Lil' Red's Mom's Avatar
Lil' Red's Mom
Hey..had to go dig this up, we were having the same issue and noticed one day after washing the car that the water did not drain out of the pan that the spoiler sits in..there are 2 drains(one on each side) and the drivers side would let the water drain out, but the side didn't and that is the side that the "water" would run into the car from. Took the car to the dealer and they found that the drain tube on that side was kinked and not letting the water drain. Had to order one from Germany and it is now been replaced. No more water running in at large amount.
To check, raise the spoiler and pour a cup of water into the drain areas on both sides and see if it drains out across the bumper.
Old Jun 24, 2014 | 11:32 AM
ChuxBiz's Avatar
ChuxBiz
Gonna' check Andy-Capp tonight when I get home. Same thing happens to him every time it rains or even after a wash job in the driveway. I'll report results.
Old Jun 24, 2014 | 05:28 PM
Grumpy_i_m's Avatar
Grumpy_i_m
I experience the the same thing every time the coupe is washed or right after it has rained. I have learned to open the hatch slowly and let it drain out. I occasionally get a few drops in the boot. Also if I let it set without opening the hatch right away it will drain out of the channels within a few minutes. I am not sure if it will be a problem in the long term but no issues now.
It seems to be in the design
Keep Motorin'
Old Jun 24, 2014 | 09:15 PM
ChuxBiz's Avatar
ChuxBiz
Angry
Nope, blocked drain not my problem. Water intrusion into the spoiler bay drains out on top of bumper as designed. My issue is the same as Grumpy's and my fix so far is the same too. It's just frustrating to S-L-O-W-L-Y open the hatch while standing in the rain!
Old Jun 25, 2014 | 11:42 AM
ChuxBiz's Avatar
ChuxBiz
Keep Motorin'
We had a hard rain shower this morning, it stopped ~08:30. I went out to Andy-Capp at 10:45 and opened the hatch slower than normal and water still drained from the channel and dripped into the boot. Guess I'll just not use the hatch if there's any chance of trapped water present 'till I can come up with a work-around. The driving fun greatly outweighs this small detail!
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
vulkandino
Oct 31, 2015 08:29 PM
martinb
Oct 7, 2015 05:00 PM
