Car wont start...battery is fine...brand new starter!
Old Mar 2, 2012 | 10:08 AM
laxpimp6903's Avatar
laxpimp6903
Sporadically, my mini will not start. The battery is brand new, and I've already replaced to starter to try and fix the problem. When I turn the key I either get a couple clicks w/ no crank or absolutely nothing!! Any ideas???
Old Mar 2, 2012 | 11:24 AM
cristo's Avatar
cristo
Alliance Member
Could be the ignition switch. They can eventually wear out and start to fail.
First thought of the clutch pedal magnetic switch, but that shouldn't even give you a couple clicks if it's not working.
Also definitely double check the battery terminal connections.
The immobilizer module is an unlikely possibility.
Old Mar 2, 2012 | 12:20 PM
drsimmons's Avatar
drsimmons
+1 on double checking battery terminal connections. Also, since you replaced the starter, recheck those lines to make sure you don't have a lose connection.
Old Mar 2, 2012 | 01:38 PM
Capt_bj's Avatar
Capt_bj
if it was me, I'd try to jump it to be SURE the battery isn't the issue
Old Mar 2, 2012 | 01:47 PM
drsimmons's Avatar
drsimmons
^^^That's not a bad idea also. Even though it's a new battery it could still have a bad cell.
Old Mar 2, 2012 | 02:31 PM
brohammer619's Avatar
brohammer619
have you had the HPFP replaced? I'm not sure on Gen1s but this is def a problem on all BMW cars
Old Mar 2, 2012 | 02:36 PM
laxpimp6903
The car has an aux voltage gauge and it reads 12 volts so it's definitely not the batter and all the light and everything come on like it's going to start and then turn the key and maybe get a click or 2. Ignition switch seems like a likely culprit but I don't really want to just throw parts at it. Is there a way to bypass the magnetic clutch switch to see if that's the problem?
Old Mar 2, 2012 | 03:11 PM
JPMM's Avatar
JPMM
heres a few observations, and guesses
starter is not getting enough amps to work,
switch is switching.
so
the system supplying power to the starter is losing it somewhere.
could be
bad ,loose ,corroded grounds ,
bad connections on your 12 volt battery,
bad battery won't pull amps but shows 12V,
starter hot side wire loose, damaged
starter relay funked up
motor locking up , flooding
Old Mar 3, 2012 | 07:17 AM
laxpimp6903
The buddy and I are off to his shop to see what we can find. Hopefully the car won't start so we have a problem to try and fix rather than a not problem to try and find!!!
Old Mar 3, 2012 | 03:20 PM
laxpimp6903
Turns out it was all as simple as the grounding strap on the passenger side upper motor mount owing undone. I guess I spent $300 on a new starter for nothing!
Old Mar 3, 2012 | 04:26 PM
drsimmons's Avatar
drsimmons
Good deal. At least you shouldn't have to worrry about a new starter for awhile. Glad it all turned out for you.
09R56
Nov 16, 2022 10:49 AM
elightbo
Aug 17, 2015 01:50 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
