Tpms newbie question
Old Feb 26, 2012 | 01:58 PM
Tebanski's Avatar
Tebanski
I just had my 2011 MCS and want to change my stock tires with after market. I want to know if I dont put a TPMS whats the worse could happen? Is there a way to turn off the light on the dash?
Old Feb 26, 2012 | 02:01 PM
drsimmons's Avatar
drsimmons
If you are keeping the original rims and only replacing the tires, all you have to do is leave the tpms's in place, replace tires, and reset the tpms.
Only have to replace them if you are changing rims.
Old Feb 26, 2012 | 04:08 PM
Tebanski's Avatar
Tebanski
Im replacing a new set of rims and tires and i want to keep the stock just in case. What i want to know is if i put a new set of wheels and tires w/o the tpms is there a way to turn off the light on the dash and whats the worse that could happen? I miss those days we just a new pair and dont have worry bout this tmps bs.
Old Feb 26, 2012 | 04:17 PM
drsimmons's Avatar
drsimmons
Got ya. I know you can reset the tpms but as far as disconnecting it, I'm not sure plus without them I'm positive the indicator will not reset.. Maybe check to see if there is a separate fuse for it??? Or trace the wires and maybe disconnect it that way.
If the light remains on it's not going to hurt anything besides maybe being annoying looking at it all the time.
I'm with you on the good ole days when you just check your pressure weekly or so. New and improved. Right. Those damn tpms sensors are about $50 a piece and they are fragile as well.
Good luck.
Old Feb 26, 2012 | 04:27 PM
Tebanski's Avatar
Tebanski
Drsimmons I appreciate you help. I'll try that fuse thing, if not i'll just wait till my stock tires ware off dont want to spend $200 for f'n tpms . $50 to transfer it aready pisin me off lol
Old Feb 27, 2012 | 04:59 AM
yetti96's Avatar
yetti96
The light will stay on.
You may be able to turn it off using NCS Expert but I am not 100% sure on that. Either swap sensors, get new ones, or deal with the light and experiment with coding the car. There will not be just a fuse for TPMS that you could pull and make the car as well as you happy.
Old Feb 27, 2012 | 05:19 AM
richardsperry's Avatar
richardsperry
Just bite the bullet and get a set of new sensors, $212 from tire rack.
That way you could get a set of snow tires (if you live an a place that gets snow..lol) and keep that stupid light (meant for stupid people that don't know you should check tire pressures occasionally) off.
Old Feb 27, 2012 | 06:37 AM
Island maser's Avatar
Island maser
I do not have the sensors in my tack tires. You do get the warning light but who cares. When I swap back to stock I just do a reset and all is good.
Old Feb 27, 2012 | 11:32 AM
pepperstripes's Avatar
pepperstripes
How difficult is it to romove the TPMS's and move them to a different set of rims? Would the tires need to be reomved? I would be doing this twice a year to support summer and winter wheels.
Old Feb 27, 2012 | 11:50 AM
yetti96's Avatar
yetti96
You have to dismount the tire at least partially. You break the bead and get it out by turning the nut on the outside and it falls to the inside, right into your smooshed waiting hand.
If doing this once a year IMO get a 2nd set of sensors.
Old Feb 27, 2012 | 11:58 AM
drsimmons's Avatar
drsimmons
Yes, another, they are removable but they are fragile also.
They are connected to the valve stem on the inside of the tire.
Just buy a new set with the new rims then you are done.
Old Feb 27, 2012 | 12:25 PM
WeaverNH's Avatar
WeaverNH
If all else fails just put a small bit of black electical tape in front of the TPMS light. It will be visable at night, but at least it would be out of sight out of mind during the day. Of course, buying a set of new sensors is the solution if the new wheels have a spot to mount them.
Old Feb 28, 2012 | 10:25 AM
pepperstripes
So not all wheels accommodate TPMS sensors?!?
How can one tell which will and which won't?
Old Feb 28, 2012 | 10:33 AM
drsimmons's Avatar
drsimmons
I think any wheel will accommodate the TPMS's, you have to have the metal valve stems.
I believe they attach to the backside of the stem via the nut.
Old Feb 28, 2012 | 01:58 PM
Tebanski's Avatar
Tebanski
Waever that funny man. Good one for a blonde joke lmao!
Old Feb 28, 2012 | 03:00 PM
drsimmons's Avatar
drsimmons
Oh, you'll see quite abit of those things out here believe me. The funny or absurd comments really make my day.
LOL
Old May 10, 2012 | 03:48 PM
pepperstripes
OK, yet another TPMS question:
If I have two complete sets of wheels/tires both with TPMS', will the car recognize the new TPMS' once the new wheels are mounted or is the some kind of "reset" at the dealership required?
My friend has a Honda and he just changed wheels and he had to take it to the dealer for them to reset to the new sensors and they tried to charge him $60 for that.
I am considering getting new wheels and sensors so that I can avoid tire change fees twice a year. Having to pay for a sensor reset would negate most of that benefit.
Old May 10, 2012 | 07:04 PM
drsimmons's Avatar
drsimmons
The car should recognize the TPMS's regardless. However, when I put my new wheels on (with new TPMS's) I had to reset it. You can do it yourself with the stick button. I had a flat once and my tire light came on after they installed the tire. I reset it also. Once you hit the reset you have to drive about a 1/2 mile to a mile for it to reset entirely.
No need to go to the dealer as far as I'm aware.
Old May 10, 2012 | 07:19 PM
richardsperry
Correct. Just make sure that you get the correct sensors. MINI changed to a different frequency for 2010+ 433mHz if I'm not mistaken. About $230 all in for the sensors and stems. for new wheels.
Old May 10, 2012 | 09:34 PM
pepperstripes
Thanks Richard and Dr Simmons. That's what I needed to know.
Old May 22, 2012 | 02:41 AM
Btwyx's Avatar
Btwyx
Wanting to charge him $60 for a TPMS reset is a rip-off, they should have just showed him the right procedure and sent him on his way.
Old May 22, 2012 | 02:04 PM
jomama's Avatar
jomama
i'm sure it's in the owner's manual as well. if the friend is to lazy to read it, he/she has no one to blame for being ripped off.
Old May 22, 2012 | 02:17 PM
Dozuki01's Avatar
Dozuki01
Yup - It seems they are different between for the 2009 and 2010+
I just bought a new (almost new) 2011 MSC OEM rim with tires from a member on this forum and they had TPMS but my 2009 Clubman would not recognize and activate the TPMS to reset. The lights do stay on all the time...
My car is at the dealer for other services and I asked them to take a look and we will know the outcome. Hopefully, I don't have to buy a new set of TPMS.
If I do then I will have the 2011 TPMS available if someone need them.
Old May 22, 2012 | 02:21 PM
Dozuki01's Avatar
Dozuki01
When you order a new set of wheels and tires from Tire Racks you can add the TPMS option and Tire Rack will mount the correct TPMS for the correct year and model of you Mini. Once you get the new wheels and tires the reset is the same way as you do with your current setup.
Old May 22, 2012 | 03:39 PM
mcl1970's Avatar
mcl1970
Closest thread I could find to my question.
I've read so far that NOT having TPM sensors will not affect the performance of my '07 Cooper S. Does anyone have hands on experience with this?
The reason I ask is: I just had three new rims and tires installed. The forth was the wrong size, so another has been ordered. They swapped over my TPMS from my old rims. They only noticed that the forth rim was wrong after they had removed the TPMS from my old rim and remounted an old tire to it (for a spare). So, now I have three new rims and tires with the TPMS installed. One old tire and rim with no TPMS at all. After I got home and started it this morning it had gone into limp mode. Is it possible that having only three TPMS installed could have triggered this? Aside from being down on power it runs fine.
Any help would be greatly appriciated!
