R50/53 will an 08 convert suspension fit in an 05 s?
Old Feb 21, 2012 | 05:05 PM
Autobot_Lazi's Avatar
Autobot_Lazi
Can someone help me with this question? will a 2008 mini cooper convertible suspension fit in a 2005 s?
Old Feb 21, 2012 | 05:50 PM
ZippyNH's Avatar
ZippyNH
Both cars are gen1, and gen1 suspensions are generly interchangeble, except on a few of the earlist cars. One tip...the springs (oem ones anyway) used on a mini are calculated based up the cars exact weight, including options (mostly sunroof/transmission/hardtop), so swapping the springs might not be a good idea, but shocks/struts if lightly used might be ok.
Old Feb 21, 2012 | 05:52 PM
Autobot_Lazi
but the 2008convertible is a gen 2 isnt it? so that means it wont fit?
Old Feb 21, 2012 | 06:00 PM
ZippyNH's Avatar
ZippyNH
Nope.
gen1.
the cabrio, built on the r50/r53 platform continued in production for 2 more years after the gen 2 was introduced...the cabrio is called the r52, and was built till the 2009 was introduced as a gen2. Confusing, sure, but the 2 year delay was caused due to the extra engineering needed to make a ragtop (thats what it was attritubuted too anyway).
Old Feb 21, 2012 | 06:03 PM
Autobot_Lazi
so if i buy the guys 2008 mini cooper convertible springs and shocks, it will fit in my 2005 mini cooper s jcw
Old Feb 21, 2012 | 06:04 PM
miniblucabrio's Avatar
miniblucabrio
Nope R52 2005-2008 R57 2009+
Old Feb 21, 2012 | 06:08 PM
Autobot_Lazi
OK i am more confused now. do you mean nope it dont fit? i have an r53. will the r52 suspension fit my r53. can someone reply back with a yes the r52 will fit your car or no the r52 supsension wont fit your car.
thank you
Old Feb 21, 2012 | 06:39 PM
ZippyNH's Avatar
ZippyNH
Needs a , to make it more readable...the r52, built on the r50/r53 chasis was built till 2008. The 2009+ is the r57.
why getting rid of the JCW springs?
Getting springs with the WRONG spring rate (cabrio to hard top, maybe different options=different weight) can result in a poor ride. Aftermarket springs are generaly sold based upon typical weights, but oem one are tuned (they are tested when made, then grouped in similar spring rate groups, and shipped to the appropriate car). That is why the dealer needs a vin# to order springs.
almost 100% of non trim cabrio gen 1 parts are compatible with the gardtop and viseversa...one exception is the exhaust on the s, it was changed on all 2005+ s cars to fit an extra brace added to the cabrio...that is why the jcw exaust has a pre 2005, and a post 2005 part number(there is a slight crimp in the pipe where it passes the support added to it), so in that case the new part is backward compatible.
back to the op's question...they will "fit", not sure they will be optimum though...ride may be choppy...
If you need a better ride than the jcw (very mild drop), you might be able to use knoi golds....
Old Feb 21, 2012 | 06:44 PM
Autobot_Lazi
I have eibach coilovers on my car right now. But the person that wants to buy myh car wants the factory springs. He doesnt want it lowered. so I am pulling the factory springs out and putting in the 2008 if it fits. so thats why i want to know if it will fit.
so should i buy the 2008 convertible springs and shocks to put in my r53? will it fit?
QUOTE=ZippyNH;3457394]
If you need a better ride than the jcw (very mild drop), you might be able to use knoi golds....[/QUOTE]
Old Feb 21, 2012 | 07:34 PM
Autobot_Lazi
ok i guess it will fit. thx all
Old Feb 22, 2012 | 12:52 AM
BlwnAway's Avatar
BlwnAway
Yes they should "fit".
The only diference would be the ride, just because the Cabrio is heavier, but honestly if your '05 JCW came with the "Sport" suspension it will prob. be very similar.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
Emnotek
Aug 13, 2015 05:47 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
