R56 How to remove R56 Driving Lamps?
We plan on pulling the driving lamps off the car - they were installed from the factory so we are curious to know how hard it is to remove the whole system. Any links or writeups would be appreciated. Thanks.
I just did this middle of last year.
Are you looking to remove the wiring as well that attached to the foot-well module (FRM)?
The lights, brackets and connections are pretty self explanatory; simply unbolt from the front end fascia assembly.
You will need a replacement grill that has not been cut for the backets.
If you're looking to remove the wiring, you will need to make a few cuts to remove connectors as they do not pass through the firewall.
Also, you will need a replacement knee bump guard that doesn't have the light switch.
- Erik
- Erik
What are you going to do with the units you remove? I am in need of the front passenger side lamp. I just bought a car and the lady hit a jackrabbit and took the lamp and part of the bumper out.... ouch...
DWooderson
Aug 10, 2015 09:12 AM
