R56 Which brake lines are which?
Seriously ? You only need to see one end. I have to have the rears moded for a customs brake install. This is the problem with forums today you ask questions and you get troll responses. I would pull the wheels off but it's not going to matter since the lines are totally different.
At least on my 2008, there is no difference between the front and rear brake lines except for the length. All of the connections are the same. Hence, the reason you need to pull the wheels off so you can check the length. But iirc, the longer lines go on the rear - been a while since I swapped mine though.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
