R56 Need help with warning symbol
Old Feb 2, 2012 | 11:02 AM
army scope jockey's Avatar
army scope jockey
Anyone know what the triangle with the ! in the odometer means? FWIW I have an 08 Mini Cooper S.
Old Feb 2, 2012 | 11:26 AM
wandrur's Avatar
wandrur
Moderator
Could be any number of things. Are there any other lights lit up on you big speedometer?
Old Feb 2, 2012 | 11:28 AM
Perihelion's Avatar
Perihelion
Click the stalk button until you get to the Check-Info option then long-press. Cycle through to the Check option and long-press. That will bring the warning up on the tach screen.
army scope jockey
Nope, just the small triangle. Seems most of the stuff in the owners manual shows all the big symbols and they are usually in yellow.
Old Feb 2, 2012 | 12:31 PM
murdoc's Avatar
murdoc
Could be that it is below 37F. I know that at that temp, the car "bongs" at me and shows that little symbol in the tach. IIRC last winter it stayed there but I didn't always get the "bong" when I started the car.
Old Feb 2, 2012 | 12:39 PM
wandrur's Avatar
wandrur
Moderator
The temperature warning should go away when the little snowflake goes away.
If your washer fluid is low, you'll get the triangle. Same with low fuel. Perihelion has it right--check the stalk and see what it tells you.
Old Feb 3, 2012 | 01:23 PM
strobeyprobey's Avatar
strobeyprobey
https://www.northamericanmotoring.co...376-post1.html
Follow the detailed procedure I outlined in that post to determine the exact error you have!
randeez
Oct 5, 2015 09:23 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
ericf1993
Sep 26, 2015 03:58 PM
rt808
Sep 25, 2015 01:59 PM
