R56 oil change settings
Old Jan 31, 2012 | 08:27 PM
genik's Avatar
genik
oil change settings
Recently i changed the motor oil but the technician did not update the notification on lcd dashboard. How do i do it by my self so i get notification for the next time needed to change oil?
Old Jan 31, 2012 | 08:34 PM
OceanMini2's Avatar
OceanMini2
http://www.youtube.com/watch?v=IEpxN9qhFFo
Old Jan 31, 2012 | 08:43 PM
PatM's Avatar
PatM
Did you change it when the computer told you to change it or did you change it when you wanted too? If the car is newer and still has the dealer paid oil changes you do not want to change the computer interval if it was not telling you to do so. Otherwise you will not get your free oil changes.
Old Jan 31, 2012 | 10:19 PM
cccplus's Avatar
cccplus
You should get an oil change at the dealer annually or within the 15k miles so that the dealer don't have a reason to void your warranty for not having any records of oil maintenance.
Old Feb 1, 2012 | 01:35 AM
genik's Avatar
genik
i changed it when i wanted to yes, cant i set the computer for the new oil change?
Old Feb 1, 2012 | 01:48 AM
genik's Avatar
genik
Originally Posted by OceanMini2
the guy here does something wrong, he doesn't replace the copper washer when he unscrews the oil carter lid! washer must be replaced because when its new it is tubular inside, so when screwed its compressed/sqeezed so its firm and will not drain any oil
Old Feb 1, 2012 | 04:54 AM
Subzero's Avatar
Subzero
Like PatM said, it depends on whether you are still within the window of free maintenance or not. If you are still eligible for free oil changes from the dealer, you should not reset it. If you reset it, the computer will then extend your maintenance mileage back to ~15,000 miles, negating your ability to get your free oil change from the dealer.
If you are beyond the period of free maintenance, then feel free to reset it at will.
Interesting note, I paid my dealer to do an oil change at 3000 miles, and requested that they not reset the counter for the above reason. They said that since it's not a normally scheduled oil change that they weren't allowed to reset it even if I had wanted them to.
Cheers
Jon
Old Feb 1, 2012 | 08:26 AM
OceanMini2's Avatar
OceanMini2
Cheers
Jon
^^^My dealer said the same thing at 3000 miles ^^^
Old Feb 2, 2012 | 12:09 AM
genik's Avatar
genik
ok so ill just check with the dealer then, but just to know how do i reset it anyway? and what is the out come of the reset?
Old Feb 2, 2012 | 03:17 AM
ChrisNJ's Avatar
ChrisNJ
If it is reset you can lose the free oil change. I had the same thing at 9000 miles. Now at 14775 getting close to free oil change. They will not reset it.
Old Feb 2, 2012 | 05:40 AM
jcauseyfd's Avatar
jcauseyfd
You could do a search for "R56 service reset" or something similar and you should find the instructions posted by TWISTER. I have since found a second method for resetting the indicators that I prefer as it does not reset my trip odometer. I put the instructions together in this document (sorry, not fully documented as to sources - thanks to all who figured this stuff out).
Old Feb 2, 2012 | 08:10 AM
OceanMini2's Avatar
OceanMini2
This is not the best video but at the end he tells you how to do it. (posted above)
Old Feb 5, 2012 | 02:55 PM
Minidogs2's Avatar
Minidogs2
I've been having a running email discussion with our dealer. I've changed the oil twice in the first 15,000 miles - 3000 and 13,000. I live 3 hours from the closest dealer so the free oil changes aren't worth the drive - but a warranty for a new engine certainly is!
The dealer said to keep my receipts and hope for the best. I've got to reset the service indicator or it will look like I didn't do any service. What's the deal with the key fob somehow remembering the service history?
Old Feb 5, 2012 | 08:58 PM
PatM's Avatar
PatM
The key fob keeps the history of your engine. I think it may include any service indicators an engine malfunction codes. I don't know for certain all of the data that it captures from the ECM.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
serrow
Hawaii
Aug 19, 2015 11:35 AM
ludedude
Aug 10, 2015 07:16 PM
