R56 Boost Problem
Old Jan 30, 2012 | 07:22 AM
axleR56's Avatar
axleR56
Boost Problem
So, overall I have been very happy with my ScanGauge. However, I am suspicious that it is not displaying boost properly(or that somethings is wrong with my car). I have done the set up 3 times with the same results. I am accurately inputting all of the data into the xGauge setup and I believe the gauge is set up properly.
That being said, the highest I have ever seen my boost hit is 8.8PSI. This includes times when I floor it in 2nd, 3rd, 4th. My car does not feel weak at all, and it doesnt have any trouble holding boost at 8.8psi. During shifts, boost is held properly also.
Some info:
Scangauge readings while car is idling:
Boost: -9.9 to -10.2
MAP: 4.4-4.8
Scangauge readings while engine is off:
MAP: 14.6
Setup:
TXD: 07DF010B
RXF: 0441850B0000
RXD: 2808
MTH: 00910064FF6E
Can anybody shed some light as to what could be the issue? Im not sure if my car is just displaying boost incorrectly, if it actually ISNT making full boost, or if I am just not going the right speed/rpm to hit full boost.
Thanks in advance!
Old Jan 30, 2012 | 07:56 AM
axleR56's Avatar
axleR56
Also, I live in CT. The temperature here has been ranging between 15-45F the past few weeks.
rob&JCW
Feb 13, 2023 07:03 PM
AdrenaliNate
Nov 4, 2015 07:26 PM
PEterChoqu
Aug 26, 2015 08:33 AM
Indimanic
Aug 19, 2015 11:08 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
